Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 21-04-2015, 17:25
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Swerve designs
Originally Posted by MStump View Post
Another thing to keep in mind is with swerve comes a lot of extra parts: eight motors, eight motor controllers, four sets of gears, and another stage for rotating the gearboxes.
You will also almost certainly need at least four encoders (maybe even eight depending on how you do it!). Encoders can often be difficult to work with so if you decide to use a swerve drive during the season, it would probably be a good idea to be confident with the use of these sensors.
The only thing not included in the weights I was talking about are the extra 4 motor controllers. Everything else is on the modules. I also did not consider any of the framing because with a swerve it is hard to define where the module support rails end and the structure of the rest of the robot begins.
Encoders were our biggest issue this year, make sure you can mount them in a way that allows for "wobble" so you don't damage them.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
