Go to Post Aw... am I too late to suggest a water game? - jgannon [more]
Unread 21-04-2015, 18:29
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
Raspberry Pi C++
I am trying to get team 2168's vision tracking working on a Raspberry Pi 2, but I get this error:
./2168_Vision_Example: error while loading shared libraries: libstdc++.so.6.0.20: cannot open shared object file: No such file or directory
I have had little experience with code outside of writing it and hitting compile and send to rio, could someone help me get this working
Unread 21-04-2015, 18:36
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Raspberry Pi C++
Do you see something named "libstdc++..." on your device? I don't have a Raspberry Pi to look at but it would be typically in something like /usr/lib. If you find it, see if the version number matches.
Unread 21-04-2015, 18:48
FRC2501's Avatar
There isn't a libstdc++ in that folder, I'm assuming that means that I have to get that library?
If so how would I get that library?
Unread 21-04-2015, 19:03
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
You can statically link the library on the compiler end.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 21-04-2015, 20:06
FRC2501's Avatar
And how would I do this?
Unread 21-04-2015, 20:09
That depends on your environment... how are you building code for the pi?
Team 973 (2016-???)
日本語でOK
Unread 21-04-2015, 20:25
FRC2501's Avatar
I am using Eclipse
Unread 21-04-2015, 20:41
I am using Eclipse
Did you follow a guide? Please link it. The more detail you can provide the better.
Team 973 (2016-???)
日本語でOK
Unread 21-04-2015, 20:50
FRC2501's Avatar
I followed this guide:
https://github.com/Team2168/2168_Vision_Example
and to be honest I have no idea how the code I typed becomes the thing that runs on the roboRIO
Unread 21-04-2015, 21:26
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
I would remove what installation you have of opencv, and start fresh.
Glancing at the code, or rather what's in the repo. If you haven't, try installing opencv separate from here: https://github.com/Itseez/opencv, or by simply typing sudo apt-get install opencdv-lib. You aren't losing anything by not using their altered opencv that can change one camera's internal settings. V4L2 does this for ANY camera, well, for the most part.
Once you think it is done, run the following program to ensure everything is working:
https://github.com/rr1706/sample
Then I would try to run their program if you desire.
So in your first post you say you are using the Pi, but on your latest one you say the roboRIO....
As for your last comment indirectly about compilers: grab a book about compilers and read it. The general cs courseload for any university should include a class on compilers.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 21-04-2015, 21:50
FRC2501's Avatar
Sorry about confusing you, I am running this on a Pi, but I have the most experience with the rios, I reinstall the OpenCV, but it seems to be another C++ library not the OpenCV one that it needs.
Unread 22-04-2015, 08:20
faust1706's Avatar
I figured your installation of opencv wasn't the problem, but you never know. I don't really trust getting the opencv source from anywhere but from the repo I shared.
I think this terminal command with solve all your problems:
sudo apt-get install lib32stdc++6
Unread 23-04-2015, 19:01
FRC2501's Avatar
I tried to install it with apt-get and this came up, I did find that it has libstdc++ on it but not lib32stdc++
E: Unable to locate package lib32stdc++6
E: Couldn't find any package by regex 'lib32stdc++'
Unread 24-04-2015, 21:32
faust1706's Avatar
Um....shot in the dark here: sudo apt-get build-essential. Sorry for the rather delayed response.
Unread 28-04-2015, 18:59
FRC2501's Avatar
Ok a few things:
1. build-essential is already the newest version
2. lib32stdc++6 is not available
3. libstdc++6 is already the newest version
Doe anybody know how to fix this?
