Go to Post I learned that I don't have a clone, there are only 24 hours in a day, and I can't do everything I want to do (even though I tried) and I learned that I have to say "no" once in a while. - KathieK [more]
Unread 24-04-2015, 01:04
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: California Districts
Originally Posted by Mr V View Post
The PNW did have one of the CA RDs come up see what an event looks like and check out our Fieldhouse the center of PNW FRC operations. So they are exploring what it would look like but 2016 sounds unlikely because things need to start happening now to have everything in place in time.
Personally with the number of teams I'd say that CA should really be two separate districts as trying to start up with that many would be a huge amount of work. Yes FiM has a similar amount of teams but the worked up to that level over a number of years.
Not to mention FiM teams have a lot less traveling distance.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 24-04-2015, 01:17
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
Since I was curious about how it would look, I created a map with dots for all the FRC teams in California. Using the data from here, I used google fusion tables to create this map:
Name:	California Team and Regioinal Locations.png
Each red dot represents a city with at least one team (I'm not sure how to force google not to stack dots), and each yellow arrow is a current regional location. You can see the map and data here: https://www.google.com/fusiontables/...OZ0v 9E73XKuU
Drawing a horizontal line slightly above Bakersfield (through Las Vegas or so) would split most teams fairly cleanly. In terms of current regionals, it would be Northern/Central California with CVR, Sacramento, and SVR and Southern California with Inland Empire, LA, Ventura, and San Diego.
In terms of location, having two separate districts seems to make more sense. It would mean that most, if not all teams would be able to drive to their district champs in a reasonable amount of time (my family has driven down to LA from the bay area in a day several times before, and although definitely doable, it's not much fun). It would, however, mean that the teams that you can see at district champs will be pretty much the same ones that you've seen at district events.
It would solve the issue of finding a place that could have a large event though. There are 238 teams in California, so each of the district champs would be about the size of a current regional, possibly smaller. There were 57 teams at SVR this year, and having two events that size would mean 47.9% qualify for district champs.
For the number of events, at 35 teams per events that would come out to 13-14 events. Putting 3 of the new ones in Northern California and 3-4 in Southern California seems to be the most logical solution. (Note: I couldn't find an easy way to figure out how many teams would be in each area so I guessed) I have no idea about venues that would be willing to hold events though.
I'd guess that the current setback would be finding the volunteer base followed by getting venues. I am hoping they find a way to solve this soon...
Unread 24-04-2015, 01:28
I might go the other way, but those are the top two, I think. It's hard to find a location in CA that fits for a district/small regional without having to deal with "larger" (read: non-school) venues. I can't think of more than about half a dozen "near" L.A. (read: within a couple of hours) that would work for that, though I could probably come up with a few more if we were talking "offseason". BTW, most of the ones I can think of have hosted an event in the past.
And then you get the volunteers...I worked 3 events this year; I know some of the other volunteers worked at least that many. And the only reason I did a third was because I knew that event was short-handed. Many of the volunteers have been doing this since I was competing...
It's not an easy problem to solve, though, particularly for some key positions.
Unread 24-04-2015, 02:12
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Originally Posted by Andrew Lawrence View Post
You're more than welcome to attend it. Madtown Throwdown happens every year in early November.
Been there a couple times already, even the very first one.
I used to work at JBT FoodTech too, right down the street from the HS.
I was just saying that the Central Valley is right in the middle of California so fair traveling for both Northern and Southern teams. Might need a better location though, if only the Savemart center was available.
Good enough is the enemy of anything great!
team 1671
Unread 24-04-2015, 06:04
GaryVoshol's Avatar
Cogito ergo arbitro
I don't know about that. The team from Houghton had to travel over 500 miles to get to MSC in Grand Rapids. That's longer than the distance from San Diego to San Jose, for example.
(since 2004)
Unread 27-04-2015, 13:39
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Comments from FIRST leadership during the town hall meeting definitely made it sound like Districts in CA are far from being finalized.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 27-04-2015, 14:51
INTENSITY
Between leadership changes, a growing number of teams, and less funds available to teams this year, I would imagine we're still quite a ways away.
