Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-24-2015, 11:53 AM
raystubbs's Avatar
raystubbs raystubbs is offline
Programmer, Builder, Designer
FRC #2657 (Thundercats)
Team Role: Student
raystubbs will become famous soon enough
Re: RoboDS First Test
Here is a brief description of my app, and a prompt for some suggestions. Currently the app supports a 'drag n' drop' interface builder with 'Basic Button' and 'Basic Joystick' components. The app was designed so that new widgets of each category (joystick, button, slider, switch, throttle, etc.) can be easily added, so by the time the app is finished I hope to have a collection of widgets in different styles, and to allow users to import their own. The app's action bar contains a voltage indicator, connection indicator, enable button, mode switch, and a menu with settings and layout editing options. When a new widget is added to the layout a dialog comes up asking for the widget settings (joystick number, axis number, size, etc.). I plan to add support for multiple layouts that can be quickly switched out, but that'll have to wait until after the first release. Also in updated versions I'll add support for video and hardware joysticks. Video streaming is NOT currently supported in the app.
I also plan to add indicators to the widget collection, these'll include gauges, LEDs, and a few others. But to use these components the robot will have to include some RoboDS specific code, I don't want to use Smart Dashboard code because I want it to be a little smaller and lighter then the full Smart Dashboard implementation.
So here is a prompt:
I prefer to use RoboDS in landscape mode since I have a tablet. I do NOT want the app to change orientation with the sensor. So does anyone want an option to set the orientation of layouts to portrait? Is it easier to use a phone in portrait?
Any other suggested features?
The source code will be put up on Github after the first APK release, so if you'd like to branch it and add your own features feel free to do so.
"If all else fails, read the instructions."
