Go to Post It's what this is all about. Making dreams happen. - Astronouth7303 [more]
Unread 16-01-2002, 21:39
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Lifting goals
I wanted to point out a rule that is easy to overlook, and I've heard other teams talk about it so we're not the only one caught by surprise... It appears we can not lift the goal or provide any force on the plywood on the goals. rules GM20, GM21, and GM22 talk about this. Our team's asked a whole set of questions which should clarify these rules. I'll post here anything I hear.
Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 16-01-2002, 22:39
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Please let me know of everything you find out. Our team might have to make design changes.
~Tom Fairchild~
Unread 16-01-2002, 23:01
patrickrd's Avatar
AKA: Patrick Dingle
This is the latest from the Yahoo board...
http://groups.yahoo.com/group/FRCtech2002/message/309
Message 309
"A) GM20 does NOT exclude interacting with the lower surface of the upper deck or, conversely, interacting with the upper surface of the lower deck. However, if by interacting with the lower surface of the upper deck, for example, you apply enough upward pressure to it to allow the goal to be pulled or pushed, then FIRST would consider you to be attached... which is disallowed. In a nutshell, incidental interaction, such as to "sense" where the surface is or with robot arms extending/retracting in that area, is allowed and expected."
Message 207
"Can a robot deliberately interact with the bottom of the upper plywood platform of the goal (as long as it does not cause damage)?
A) No. FIRSTsnow"
Message 120
"To be clear, see rules GM21 and GM22. A robot could react against the lower surface of the upper plywood if it did not attach to it and did not present a risk of tipping the goal over."
Message 207 and 120 are definately contradicting each other. Rules GM21 and GM22 do not state rules, rather examples of what is acceptable or not. I think FIRST needs to set rules (standards) which clearly differentiate acceptable from unacceptable, rather than arbitrarily giving examples of what is acceptable and not.
Unread 16-01-2002, 23:13
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
309 was my question. I understand ( as of today) that the plywood is off limits for up-loading weight to your bot, but the pipe and flanges are not. Just design to hit the flanges... Thats the ticket as far as I can tell...
Unread 16-01-2002, 23:15
FRC Key Volunteer Trainer
AKA: CrazyNate
I spoke with someone at FIRST today regarding this conflicting posting...and the newest post(309) is the final ruling...just like there is miscommunication within all of our teams at times, it appears there was some miscommuncation within FIRST as to the correct answer to these questions. I'm willing to forgive them, they're only human after all
Nate Smith
nsmith@smythsoft.com
Unread 17-01-2002, 17:19
patrickrd's Avatar
AKA: Patrick Dingle
Another conflicting response...
It appears we *can* now uplift goals, contrary to rule GM20, if we grab the bar. Or is FIRST's definition of uplifting synonomous with tipping over?
Patrick
"Q: >>If our robot could grab a bar and tip the goal slightly, could
it be
placed on top of the other goal so as to have an overlap of a few
inches? <<
A: Yes, but if this is part of your strategy, don't violate the DQ
rules on damaging the playing field, or the DA rules on disabling
violations."
Unread 17-01-2002, 17:58
AKA: CrazyNate
This isn't actually conflicting based on how I'm reading it...GM20 says we cannot upend(tip over) a goal, attach to the plywood, reach under the lower base, or grab onto certain parts of the goal. Keep in mind that upend=tip over for all general purposes. My reading of the rulings they have made regarding this issue is that we can still pick up the goals, but we have to use only the steel pipe and flanges to do so.
Nate Smith
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
can someone help me with the goals? archiver 2001 2 23-06-2002 23:15
Fork Lift Robot tinyfarnsworth General Forum 64 16-04-2002 12:09
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
