Go to Post ...and part of being Graciously Professional is knowing what your job is and how to perform the duties of it accurately. - jamie_1930 [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Unread 27-04-2015, 02:01
will4499 will4499 is offline
FRC #4499
will4499 is an unknown quantity at this point
Fastest Possible Canburglar
I wrote a python script to calculate the fastest possible canburglar you could make if it was powered by motors... it appears to be in the 20 ms range. This was inspired by the can burglar from 973 that we were putting on our robot in place of the "tail" at the championship. Let me know what you think.
I attached the python file as canburglar.txt and a pdf which I used for some of the equations. Here is the code:
import math
## Using SI Units - kg, m, s, current in Amperes, angles are printed in degrees but calculations are in radians
##System
t = 0
e = 2.718281828459045
dt = 0.001
rod_mass = .15 # kg
rod_length = 2.5 # m
hook_mass = .05 # kg
J = ((16/48) * rod_mass * (rod_length ** 2)) + hook_mass * (rod_length ** 2) ## rod moment of inertia + hook moment of inertia
angle = 0
terminalangle = 90 * (math.pi / 180) # in radians
#Motor Banebots RS-775 down-regulated to 12v
motor_num = 4
motor_stall_I = 100
motor_stall_T = 1.175
motor_free_omega = 13000 * math.pi * 2
geardown = 1
test_endpoint = 3000
print(motor_free_omega)
def getVelocity():
power_term = -((motor_stall_T * motor_num * geardown)/ (J * (motor_free_omega / geardown))) * t
return (motor_free_omega / geardown) * (1 - e ** power_term)
lowestt = 1, 1, 10000 # low geardown, high geardown, time
while (geardown <= test_endpoint):
#print("terminal velocity = " + str(motor_free_omega / geardown / (2 * math.pi)))
while angle < terminalangle:
angle += getVelocity() * dt
t += dt
print("terminal velocity = " + str(motor_free_omega / geardown / (2 * math.pi)) + " rpm " + " geardown = " + str(geardown) + " angle = " + str(angle / (math.pi / 180) ) + " t = " + str(t) + " velocity = " + str(getVelocity() / (2 * math.pi)) + " rpm " + " \n")
#print("geardown = " + str(geardown) + " angle = " + str(angle / (math.pi / 180) ) + " t = " + str(t))
if (lowestt[2] > t):
lowestt = geardown, geardown, t
elif lowestt[2] == t:
lowestt = lowestt[0], geardown, t
t = 0
angle = 0
geardown += 1
print("fastest canburglar, geardown = " + str(lowestt[0]) + " :")
geardown = lowestt[0]
t += dt
if (test_endpoint == lowestt[1]):
print("******************************************* ************************************************** **********************************************")
print("**************** Warning, you may not have found the absolute minimum for cangrabber speed. Increase test_endpoint. ***********************")
else:
print(" Choose a gear ratio between " + str(lowestt[0]) + " and " + str(lowestt[1]))
Unread 27-04-2015, 07:29
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Fastest Possible Canburglar
Only four rs775s? With four CIMs we got .18 seconds.
Unread 27-04-2015, 08:05
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
What about elastic//spring powered? I could see that being much faster.
Unread 27-04-2015, 08:15
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
You can get slightly faster times if the gear ratio is not constant. A linkage or, non-round pulley or sprocket set can accomplish this.
Do you account for voltage drop? Stalling all those motors drops the voltage considerably.
Do you consider the inertia of the motors? With the gear reduction, they end up making a significant contribution to the inertia of the system.
This is a good first step. Simulations should always start simply, and add other factors and complexity as you prove it out.
Unread 27-04-2015, 13:39
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
This guy knows whats up.
Unread 27-04-2015, 14:04
Volunteer, WPILib Contributor
no team (Waiting for 2021)
I'll explain when I have a few minutes and not on my cell phone, but we figured out a way to start in the holes legally. It was cheesecaked onto our 4th bot, but since it basically put a robot out of commission it wasn't worth playing in finals. Plus we were not exactly sure if it would be called legal or not, even though it was 100% within the rules and within the field.
Team 4488 - Mentor 2013-2016
Unread 27-04-2015, 14:15
Jared Russell's Avatar
Taking a year (mostly) off
I heard about this, double checked all the pertinent rules, and then grinned ear to ear. I'll let you post the details, but I was definitely blown away by your creativity.
One interesting aspect of this game is that the canburglar wars didn't really start until the last day of the season (as predicted by many). A side effect of this is that the canburglar rules/corner cases/how rules would be enforced by inspectors and referees were not really tested until Championships. Harpoon guns, crossbows, tennis balls on strings, hundreds of pounds of spring force, loopholes - there was a little of everything.
Unread 27-04-2015, 14:27
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
I'm interested, posting so I can remember to come back later.
Unread 27-04-2015, 14:31
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is online now
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
I also found a flaw... hope we've found the same
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Your interpretation is entirely legal by the rules, and It definitely would have broken the game. Please post pictures when you can. From the descriptions I can only imagine how massive this thing would be.
The real question is do you think you could do all the set-up required in under 60 seconds?
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 27-04-2015, 14:32
Engineering Mentor
AKA: Steve Bennett
Ha! Nice find! I wish you had done it, it might have led to some interesting and productive discussions regarding lawyering and the assumed intent of the rules.
I asked a head ref about a similar case, and he said that he couldn't rule without seeing it, but said he would probably have asked the team to come back and fix the offending mechanism.
Unread 27-04-2015, 14:39
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
<G10> does not require set-up in less than 60 seconds, only that set-up must not cause a significant or repeated delay to starting a match. The 60 section portion in the blue box is simply an example. There is not set time to when a 60 second clock would start, how to distinguish it from regular autonomous set up (which frequently takes longer than 60 seconds), etc.
I am very curious as to how it satisfied <G7> B&C while being within the field borders, though.
Unread 27-04-2015, 14:42
This was often not enforced as intended. Seeing refs standing around kids with stopwatches at events this year looking to peg people was disappointing to say the least.
Founding Member
Unread 27-04-2015, 14:43
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
FIELD includes the width of the guardrail, and LANDFILL ZONE doesn't include the "and including" wording. That's my guess.
FIELD – a roughly 27 ft. x 54 ft. carpeted area, bounded by and including the GUARDRAILS and ALLIANCE WALLS.
LANDFILL ZONE – the infinitely tall volume bound by the plastic lip of the STEP on the ALLIANCE’S side of the FIELD, the GUARDRAIL on
each side, and the landfill line (excluding the tape).
Unread 27-04-2015, 14:54
Bingo
Founding Member
