Go to Post Or you can always say "we programmed it that way." - probizzle [more]
Unread 27-04-2015, 18:22
Re: 2015 RoboRIO/Control System Feedback
Originally Posted by Thad House View Post
Oh thats good to know. I didn't see that get published anywhere. For demos in the past where WiFi connection was awful, we would sometimes put the computer in the robot, and use a wireless keyboard or controller to enable and disable the robot. Good to know there is still a button combination to allow this.
See #2. http://wpilib.screenstepslive.com/s/...e#OperationTab
Unread 27-04-2015, 23:00
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
I posted before on my feelings about the success of the control system. We need a physically rough game to make a final statement of success (hint hint GDC).
We used the current monitoring as a substitute for limit switches in one scenario.
Some areas for improvement:
. Transition between tethered in the pit and connected to the field was a continual issue.
. Certain laptops had trouble connecting when operating on battery. Theory is that certain network chipsets have some deep power saving mode that interferes with connectivity.
. physical retention for control cables at the roboRIO -- maybe someone should design a 3d printed part that sticks to the top/side of the unit, with retention like the Jaguar?
. Time between cold boot of robot and field connectivity was a lot longer this year than last. We actively avoided the power cycle this year, because it took so long. Maybe that was good, though, in the end, because we identified some faster ways of fixing things.
Regarding the complaint about match length, we did a fair amount of checking match length at one regional and didn't run into issues with running time. Jared, was there an event you noticed the issue at?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 27-04-2015, 23:58
JamesD's Avatar
JamesD JamesD is offline
[:o)
AKA: James David
FRC #0330 (BeachBots)
JamesD is an unknown quantity at this point
I've noticed this for several years now. You need to go into the properties of the WiFi adapter on the laptop and disable all power saving options. Otherwise when the battery gets below a certain level the Wifi adapter will actually disappear from the operating system until the power cord is plugged in again.
Team 111 Wildstang did this season: http://wildstang.org/blog/?p=225
Unread 29-04-2015, 23:57
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
We used the Wildstang part this year, worked like a charm.
Thanks 111!
Software Mentor
3853 Pridetronics[
Unread 30-04-2015, 11:42
AKA: Steve Peterson
Thanks for the pointer. I noticed in today's email blast that AM has a product to address this as well.
