Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 27-04-2015, 20:26
Jared's Avatar
Jared Jared is offline
Re: Interesting material usage?
We used kong dog toys as part of our intake rollers, which worked surprisingly well. The top is almost a perfect press fit for a half inch hex shaft.
  #62   Spotlight this post!
Unread 27-04-2015, 23:00
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
we had a fair bit of parts on our robot that were machined out of nylon, like sprockets, and such, last year we had a bearing/motor mount made out of nylon. we also use plenty of aeroplane tape, all of our electronics are held down with it .
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
  #63   Spotlight this post!
Unread 27-04-2015, 23:48
ToddF's Avatar
ToddF ToddF is online now
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
What is aeroplane tape?
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #64   Spotlight this post!
Unread 28-04-2015, 08:42
Tinmint1's Avatar
Tinmint1 Tinmint1 is offline
AKA: Erin
FRC #4575 (Tin mints)
Team Role: Driver
Tinmint1 is on a distinguished road
Our 2014 robot used a cocacola bottle to hit our limit switch which had been positioned to low.
  #65   Spotlight this post!
Unread 28-04-2015, 13:32
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
I believe it's referencing this type of tape:
http://en.wikipedia.org/wiki/Speed_tape
  #66   Spotlight this post!
Unread 28-04-2015, 13:43
LenaBug LenaBug is offline
FRC #1868 (Space Cookies)
Team Role: CAD
Rookie Year: 2015
LenaBug is an unknown quantity at this point
1868 had a ramp for the human player station that we built out of cardboard from one of the pool noodle boxes and packing foam this year.
  #67   Spotlight this post!
Unread 28-04-2015, 14:50
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
This made me do a double take when I saw it in queue.
I'll have to keep this in mind for future angled game pieces.
  #68   Spotlight this post!
Unread 30-04-2015, 19:23
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
On Carson, I saw a rookie team on my pit tour (don't recall the team number or name) with a lift frame made from an aluminum ladder. Light, strong, square, low effort. Genius!
This year (Recycle Rush) we used:
  • foam insulating tape as a gripper for our tote flipper.
  • While we pulled it off before competition, we converted a tape measure into a string potentiometer to determine our lift's height. In a brief fit of elegance, we used a backwards volume control knob as a hub for the potentiometer.
  • By drilling a single hole in each, we turned some thumb screws into combination lift chain mounts and tensioners.
  • We spring-loaded twenty 10-32x3" machine screws in some c-channel to make a "contour gauge" style tote/RC pickup that could pick up one tote from the long end, or two from the short end.
  • We designed (but did not build) a lift brake from a KOP wheel, a pipe strap, some carpeting, and a pneumatic cylinder.
A few of the other items we have used or prototyped with include:
  • strap hinges as pneumatic cylinder mounts
  • a T-hinge and a turnbuckle as a belt tensioner.
  • Lego League motors, shaft, and wheels as a frisbee intake control.
  • Pool noodles for lots of strange things, including Oscar the Grouch's eyebrow and lower lip
  • the cap from a can of Bengal Roach Spray (Guaranteed to Work!) as a ball lifter
  • Bungee cords as springs and for management of moving wires
  • More automotive electrical components and accessories than I could list
  • A rubbermaid tote to keep the rain off the controls of our t-shirt cannon
  #69   Spotlight this post!
Unread 30-04-2015, 20:09
Rebecca Pelzer's Avatar
Rebecca Pelzer Rebecca Pelzer is offline
FRC #3959
Rebecca Pelzer is an unknown quantity at this point
Oh god, was it the one with the foam underneath to strengthen it? Because that thing left bits of foam everywhere!
I was part of the reset crew for Carver and had to keep going back across the field because there were little white spheres stuck to things that had gone totally un-seen until *right before* matches.
  #70   Spotlight this post!
Unread 01-05-2015, 00:13
Easy and effective, yes. But it wasn't on their BOM. I had to explain to them how to list things at "market cost" even if they were donated.
  #71   Spotlight this post!
Unread 01-05-2015, 01:00
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
At least you asked to see their BoM...
Our inspector said "nah, don't worry about it" while i had BoM in hand.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #72   Spotlight this post!
Unread 01-05-2015, 01:35
Rachel Lim Rachel Lim is offline
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
See, I had good reasons to suggest covering it in tape... *cough*Elizabeth*cough*Elena*cough*
Sorry for the mess. Hopefully we won't be using styrofoam again, but if we do, we'll make sure it's all properly covered. I'm not sure if we'll see you again, so this is our apology to all Carver field reset volunteers who had to deal with our ramp:
  #73   Spotlight this post!
Unread 01-05-2015, 10:51
I saw a rookie team use these chains with attachments at Champs:
http://www.peerchain.com/product-cat...ultural-chain/
  #74   Spotlight this post!
Unread 01-05-2015, 12:28
Mr. Tatorscout's Avatar
Mr. Tatorscout Mr. Tatorscout is offline
AKA: Stuart King
FRC #2122 (Team Tators)
Mr. Tatorscout will become famous soon enoughMr. Tatorscout will become famous soon enough
Originally Posted by Gdeaver View Post
In some parts of the world bamboo is a structural material. Anybody ever use it on a bot?
Team Tators used Bamboo from my garden in the CalGames 2013 offseason as a frisbee blocker cheesecake for our partners. Covered it with pool noodles and folded it over with a net inside. Provided the perfect combination of inexpensive rigidity and flexibility. Loved the look on the slot feeders faces when they saw us installing it!
  #75   Spotlight this post!
Unread 01-05-2015, 12:46
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
3467s can grabbing arms were made from shower curtain rods.
