Go to Post It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't. - dtengineering [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #211   Spotlight this post!
Unread 27-04-2015, 16:22
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: IRI - 2015 Rule Modification Ideas?
I've seen a lot of calls to change playoffs back to best-of-3 series, but I would propose a different solution that I think still corrects all the flaws of the current system.
  • Divide the 8 alliances into two pools of 4. This can be in a predetermined fashion (e.g. 1, 4, 5, 8 and 2, 3, 6, 7) or semi-random (e.g. the sum of the alliance numbers must be between 16 and 20 for both pools). I wouldn't say it should be totally random because that could be really rough if the top 4 alliances are put together.
  • Play a round-robin series in each pool. An alliance advances after 2 wins and is eliminated after 2 losses, so two of the four alliances will advance. If two alliances begin 2-0, they move on and the pool ends. If one alliance begins 2-0, it moves on, the 0-2 alliance is eliminated, and the two 1-1 alliances face off (possibly for the second time) to determine who advances. If all four begin 1-1, each plays its third match against the alliance it has not yet played.
  • This advances four alliances to the SF, where they repeat the procedure.
  • The final two alliances play a best-of-3 series
I like the aspect of Recycle Rush's playoffs that each alliance gets to play more than one opponent, but taking the average of just 2 matches in the QF is very fluky. I don't like using averages in eliminations much at all, so I would go back to wins and losses.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
  #212   Spotlight this post!
Unread 28-04-2015, 00:57
Billfred's Avatar
Billfred Billfred is offline
A few thoughts (didn't read the thread):
1) Nuking the step would be bold, but IRI could pull it off. The entire landfill zone is fair game, no crossing the white line on the other side, crank out a little dummy platform for the recycling containers to sit on so we don't have to re-re-re-enginner them.
2) During qualification rounds (and only qualification rounds), step containers get a loop of red or blue tape on them. Make it the ones on the drivers' right. During the autonomous period, robots can only go after their alliance's containers. Come teleop, all step containers are fair game. (And come playoffs? Man the harpoons!)
3) I'm really okay with this year's format for playoffs. If you must do W/L before finals, I'd suggest double-elimination so there's at least a little mystery to the autonomous period.
4) Yellow totes score the same as gray totes on the platform. Goodness knows teams will need them all.
5) Alliances may request one or both lines of the face-down totes be flipped right-side up before the reset signal is given from the last match, but drive teams have to help during the setup time. (This affects the landfill packing which may affect some canburglars, so it's an option play.)
  #213   Spotlight this post!
Unread 28-04-2015, 01:22
Professional Stat Padder
There's a really good idea right there. I like it.
+1 to this.
(2015-Present)
  #214   Spotlight this post!
Unread 28-04-2015, 12:27
NHoffmann's Avatar
NHoffmann NHoffmann is offline
FRC #0573 (Mech Warriors)
NHoffmann is an unknown quantity at this point
Sorry if this has already been said, but here goes:
Remove the step. In the last minute, allow robots to cross the center. Any stacks you knock over gain your team half the points that that stack was worth (rounded up), but any stacks completed during that time are worth double. Stacks completed before this time will count as permanently scored, but stacks built during this time and then knocked over will not count. Stolen full stacks scored for the alliance that took them will receive the doubled point value for the team doing the stealing. Recycling containers stolen from the top of still standing stacks would have a point value assigned to each steal, and even more bonus points assigned to whichever stack they are placed on top of. Basically, a 1-minute race to steal as many resources as you can from the other team. Balancing defense, offense, precision, and time management.
WHO ARE WE?
573!
  #215   Spotlight this post!
Unread 28-04-2015, 12:41
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Originally Posted by Paul Copioli View Post
3. Go to 2 v 2!
#3 is the most exciting for me because this reduces the need for all of the cans and makes that race less influential without significantly changing the game. It also makes an alliance really weigh the trade-offs between auton and cans.
This is an interesting thought, but I prefer Zondag's suggestions to make more cans and totes available. If the game piece limits go away, then the incentive is to get the 3rd robot on the alliance to be as productive as possible, which I find to be more exciting. Let's see 10 stacks on each side of the field.
  #216   Spotlight this post!
Unread 28-04-2015, 12:46
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Make can races an autonomous bonus. Whichever alliance gets the most cans ends up with a 20 pt bonus (or something...or just X points per can).
Then balance out however many cans by giving them to the HP station (ie. Red alliance steals 3 cans, blue steals 1, Blue gets two cans in the HP station, Red gets none), extend the HP area to an area similar to last year allowing them to place cans onto the field.
Only issue is this assumes a can race where all four cans are taken happens in every match/what to do about contested cans that are still being fought over in teleop.
  #217   Spotlight this post!
Unread 28-04-2015, 13:54
Shifter Shifter is offline
FRC #4039
Shifter is a splendid one to beholdShifter is a splendid one to beholdShifter is a splendid one to beholdShifter is a splendid one to beholdShifter is a splendid one to beholdShifter is a splendid one to beholdShifter is a splendid one to behold
Add an end game:
Yellow totes that do not start on the field may only be introduced through the chute in the last 20 seconds of the match.
At the end of the match, a stack containing one or more of these end-game yellow totes scores double (ie. one six-high stack with RC and noodle where one tote is an end-game yellow scores 2 x 42 = 84 points). If multiple stacks contain an end-game yellow tote then only the stack worth the most amount of points is doubled in value.
Perhaps the same applies for the co-op stack during qual's - would love to see teams screaming through forests of stacks in a race to co-op before the buzzer sounds.
  #218   Spotlight this post!
Unread 28-04-2015, 15:21
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
*I posted this in the IRI poll thread also.
The BEST idea I heard all season is from Dennis Jenks of 254.
Keep the game exactly the same, EXCEPT make the step cans available the last 30 seconds of the match only.
Think about that for awhile........
  #219   Spotlight this post!
Unread 28-04-2015, 15:35
CTbiker105's Avatar
CTbiker105 CTbiker105 is offline
People like grapes.
AKA: Griffin
FRC #0195 (Cyber Knights)
CTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond reputeCTbiker105 has a reputation beyond repute
It'd be interesting to see which teams could line themselves up the fastest to prepare for that. Although you may also see teams line up prior to the match and wait there until the last 30 seconds are approaching (but that would limit other alliance member's accessibility to the landfill totes).
2016|100-16-1|4 banners|4 medals (Galileo winners/Einstein semifinalists)
2015|??-??-??|5 banners|7 medals (CMP Engineering Inspiration winners/Newton finalists)
2014|73-36-0|2 banners|2 medals
2013|50-19-0|1 banner|1 medal
"Was wir für uns selbst tun, stirbt mit uns. Was wir für andere tun, verbleibt und ist unsterblich."
  #220   Spotlight this post!
Unread 28-04-2015, 15:39
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Man the harpoons!)
LOL! I sense a new battle cry coming on...
  #221   Spotlight this post!
Unread 28-04-2015, 16:01
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
With that rule, competitive alliances would need to create some uncapped tote stacks and then cap them in the end game. Most robots can't do that, because with the real rules it isn't necessary to cap existing stacks. This change would significantly hose a lot of teams.
Also, referees would have to judge whether teams jumped the gun on the can race. I find that less desirable than letting the FCS ensure that the teams all start the race at the same time.
  #222   Spotlight this post!
Unread 28-04-2015, 16:19
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
I certainly wish this was part of the original rules, but this change wouldn't affect all strategies the same so I doubt it would be an IRI change.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
  #223   Spotlight this post!
Unread 28-04-2015, 17:47
waialua359's Avatar
AKA: Glenn
Me too! This would have been so much better. An end game sort of.
  #224   Spotlight this post!
Unread 28-04-2015, 19:19
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Maybe I have not thought long enough. So far all I come up with is, pity the Head Referee who has to decide whether that robot won the race, or jumped the gun. Could be really tough to call when opposing robots try for the same can, possibly using different techniques; e.g., side claw vs. top hook. Harpoons fired from crossbows would be especially challenging.
Richard Wallace
since 2003
  #225   Spotlight this post!
Unread 28-04-2015, 20:05
GaryVoshol's Avatar
Cogito ergo arbitro
Sounds like reffing minibots all over again. No thank you!
(since 2004)
