Go to Post actually, I don't work with mechanics, so I just barely learned what Lexan was a few days ago...long story... It's amazing the variety of things FIRST teaches us!!! - tribotec_ca88 [more]
Unread 28-04-2015, 13:48
Jared Russell's Avatar
Taking a year (mostly) off
Re: 2015 RoboRIO/Control System Feedback
Originally Posted by Jared View Post
-Timertasks don't work properly if they are started before connecting to the driver station, but work if the reset button is pushed on the roboRIO. Troubleshooting this behavior is difficult, and it's never comforting when resetting or redeploying code puts the controller in a different state than a cold boot.
-Java timertask timing is worse than in previous years.
We ran into the first issue at CVR...the problem is that the scheduleAtFixedRate() method schedules execution relative to the timestamp of the first execution (and the RoboRIO initially assumes it is turned on at the beginning of the epoch), but when the robot connects to the driver station, the local clock is synched to the driver station time. Your code freaks out because it thinks it has ~45 years worth of work to do in order to catch up, and as a result your TimerTask hogs the entire CPU. TL;DR, never use scheduleAtFixedRate(). Thanks to Joe Hershberger for helping us to figure this out.
As for TimerTask timing being bad otherwise, this is because of some incomplete JNI between the HAL and WPIlibJ. Whereas LabView and C++ use the onboard hardware timer to generate interrupts for calling recurring tasks, the current implementation of TimerTask uses Thread.sleep(), which is quite unreliable. We would schedule 5 ms periods and get around 5 ms most of the time, but we would see several 10+ ms periods per second, and occasionally even 200+ ms periods.
We hacked our WPIlib JAR with some additional JNI to get to the FPGA timer and were much, much happier with our timing jitter. I think Tom submitted a patch to WPIlib, so hopefully this will be fixed for next year. It took us a long, long time to figure it all out...
Unread 28-04-2015, 14:14
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
I generally loved the new control systems and the Talon SRX motor controllers this year. Just a few requests:
1 - Please reconfigure the kernel to include POSIX message queues and semaphores. Embedded Linux is incomplete w/o these primitives.
2 - Please make it easier to use static priorities in threads. Many teams roll their own software solutions and we can't do the same things we did with VxWorks.
3 - Please use latching connectors on the roboRio. It is nearly a crime that we use the old PWM connectors in a high vibration environment.
4 - Please do not use Silverlight. It requires the client be Windoze and install a bunch of crap.
TIA
Unread 28-04-2015, 19:31
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Requiring Silverlight to manage a Linux device bugged me.
If we left the robot on for a long time, maybe 15-30 minutes, the robot would freak out. Planning to debug that later.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 29-04-2015, 11:00
Volunteer, WPILib Contributor
no team (Waiting for 2021)
This was actually an issue at Worlds, since Chrome dropped NPAPI support the week before. So we spent about 10 minutes trying to connect to the webdash, until I remembered, and we switched to IE. I would prefer to use chrome, which means they should switch to something chrome supports, and not silverlight.
Team 4488 - Mentor 2013-2016
Unread 29-04-2015, 11:26
This chrome://flags/#enable-npapi and click enable will work for another year or so until Google has said they will really remove it.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 30-04-2015, 00:19
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I agree it seems wrong, however maybe have a look at Pipelight (http://pipelight.net/cms/installation.html). Seemed to work ok for me (admittedly, I only opened the management page and clicked around, I didn't do any serious work with the roboRIO this year).
For convenience, Pipelight installation on Ubuntu (and derivatives):
sudo add-apt-repository ppa:pipelight/stable && sudo apt-get update && sudo apt-get install --install-recommends pipelight-multi && sudo pipelight-plugin --update
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
