Go to Post Doesn't matter what you use if you can't drive it. - efoote868 [more]
View Poll Results: Which changes would you like to see at IRI?
Replace some totes from the steps with RCs 50 32.89%
Add RCs to the edge of each scoring platform 33 21.71%
Increase tote points (ex:2-3) 35 23.03%
Remove throwing litter 75 49.34%
Additional co-op totes on the step give additional points (4=40, 5=50, 6=60) 52 34.21%
Remove penalties for co-op totes going over the step 87 57.24%
Let co-op totes be scored as grey totes 96 63.16%
Add an extra match for quater-finals, keep avg score, drop lowest score 71 46.71%
All of eliminations are W/L 59 38.82%
Increase the starting amount of totes for HPs 57 37.50%
Eliminate co-op 35 23.03%
Co-op totes score additional points in scored stacks 30 19.74%
Alliances can choose which totes in the landfill start upside-down 44 28.95%
Center cans cannot be grabbed until the last 30 seconds 31 20.39%
Teams can intentionally detach parts (no tethers are required) 55 36.18%
Eliminations are based on highest score 16 10.53%
Increase points of processed litter 20 13.16%
Allow a 3rd party to drive a totebot, bonus points if teams can score totebot 51 33.55%
Multiple Choice Poll. Voters: 152. You may not vote on this poll
Unread 28-04-2015, 20:45
Loose Screw's Avatar
Loose Screw Loose Screw is offline
A Loose Screw
AKA: Chris
FTC #5237 (Loose Screws)
Loose Screw is a jewel in the roughLoose Screw is a jewel in the roughLoose Screw is a jewel in the rough
IRI Rule Change Vote 2.0
I want to start off with apologizing if this seems like spam. I would like to address a few things I missed in the last poll, and if you could move all discussion to this thread (as opposed to the first poll), it would be appreciated.
I'll be taking ideas that scored well in the last poll, as well as some new ones that I had left out.
Please view each item as its own change, so if two options look good, but directly conflict with each other, vote for both.
I'm still new to Chief Delphi, so I'm learning how things work. A poll will be posted to this thread, so hold off on comments until it has been posted.
