Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 29-04-2015, 08:38
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
Tote bot (rebuild)
Hello all
Our project is almost finished. We had to rebuild the entire frame as the motors weren't compatible with the chain drive system, and could not pull the weight. We are going for a " independant" design, where the bot is being built out of the tote and the tote will just sit on top of the robot and possibly be anchored with some sort of locking system. When I say on top,I mean the robot will still be in the tote and be disguised, but the entire bottom of the box will be cut out.
I will post photos of the drive system when both axles are complete and attached to the robot
