Go to Post Frank is frank, and I like that. - rsisk [more]
Unread 28-04-2015, 18:14
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: VEX Pro Parts Feedback, 2015
The VexPro clamping gearboxes worked really well for us this year.
I really like how they can also accept VersaPlanetary (VP) gearboxes. We used a cim, using the cim adapter, into the VP gearboxes which we put onto the clamping gearboxes. We were able to test so many different gear reductions without changing the overall system. We had no failures on our lift system because of this.
Some things to change:
VexPro please give us 8 bolts and 8 nuts in the clamping gearbox assembly when you order it! We needed to use all 8 on our lift gearboxes otherwise we would see flexing on the gearbox plastic. Luckily we ordered spares so we just took the 4 from them.
Also there were some instances when we were first installing them that the hex cutout on the gearbox became stripped and made it very hard to get the nut out without destroying the plastic near the gearbox. We learned to watch the nut and be careful not to strip the cutout, but a few simple redesigns would make this problem go away.
Good enough is the enemy of anything great!
team 1671
Unread 28-04-2015, 18:18
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
6" Omni Wheels: We used 7 of these on our robots H-Drive this year. It was our first time using Omni Wheels and we were not disappointed, the wheels held up all year didn't have any issues with durability. The fact that the wheels shipped already assembled was also a huge time-saver.
Our only complaint was that we got quite a bit of material buildup (presumably from the carpet and plastic from the ramps) that proved difficult to clean up and negatively affected traction. We purchased a set of replacement wheels and swapped them out at the MSC as a precaution.
Single Speed, Double Reduction Gearboxs: We've used VexPro Ball Shifters before but this was our first time using the single speed gearboxes. The gearboxes held up all season and required no maintenance after initially assembly.
When we assembled the gearboxes, we did notice that one of the three gearboxes had some difficulty going together (the two pieces of the casing would not close all the way). Later after wiring up the gearboxes, we also noticed one of them ran very rough (sounded like grinding gears, and occasionally the gearbox seemed to "catch" on something). Disassembling and reassembling the gearboxes didn't provide a fix to the problem, but after running the gearbox under power for a while, the issue seemed to resolve itself. We're hoping to get the gearboxes apart again now that the season is over and see if we can diagnose the problem.
VersaPlanetary CIM Adaptor: Having had to make our own adapter (out of a solid block of aluminum) last year, the VexPro CIM Adapter is a welcome addition for our team. The weight savings is excellent and it held up surprisingly well to the weight of a MiniCIM cantilevered off the back of it, and along with a 35:1 Versaplanetary, drove our conveyor system without any issues.
Colson Performa Wheels: When building our tote intake this year, we initially used 4" VexPro Traction wheels, direct driven by VersaPlanetary gearboxes with bag motors, to collect totes into our robot. This proved extremely ineffective during our initial tests, so we started looking for other options. We came across the 4" x 0.875", 1/2" Hex bore Colson wheels which seemed like they would be a great fit for our collector (having heard of how great Colson wheels are from other teams for years). While the Colson wheels were far more effective at grabbing totes then the traction wheels had been, they still didn't have the grip we were looking for, and additionally, the wheels started to wear down after our first competition.
We ended up replacing the Colson wheels with 4" Urethane Drive Rollers (60A) from McMaster for our last two competitions (thanks to team 314 for the idea) which worked much better for tote collection.
We have certainly not written off Colson wheels for future projects, but they were not a good fit for our robot this year.
Suggestions:
  • Standardize wheel widths - Our initial robot design called for 6" Traction wheels, but after deciding to switch to H-Drive, we had to widen our drive base to accommodate the slightly wider 6in Omni-Wheels. Ideally, it would be nice if all same-diameter wheels were interchangeable with no modification.
  • Make a shaft spacer that mates on one side to the VersaKey pattern in wheels and gears - I absolutely hate spacers in a drive system; there is nothing worse than having to chase after a dozen tiny rolling spacers when you have to swap out a wheel or fix a chain within a few minutes. Having spacers that mated to the VersaKey pasterns on VexPro wheels and gears would greatly alleviate this issue. I actually attempted to make such spacers myself using our teams 3D printer, but it proved problematic to build without dissolveable support material or hours of sanding off regular support material.
  • It would be great if VEX stocked K1 Chain attachments for 35 chain (and 25 chain if possible). You can buy it from McMaster but it's 3 times more expensive then other sources (which have much slower shipping).
Unread 29-04-2015, 03:18
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Originally Posted by asid61 View Post
I want 3/8" hex sprockets, or at least versahubs! Why are there no 3/8" hex versahubs!?
THIS! How am I supposed to use the 3/8 hex bevel gears on a swerve module that has chain to the wheel. 3/8" hex sprockets would save us a ton of time and money.
Originally Posted by Andrew Lawrence View Post
Take this with a grain of salt based on where I'm from, but the WCP 32DP gears have to be some of my favorite products so far. They make getting a large reduction in a lightweight and compact packaging simpler and more effective than planetary gearboxes (and in my experiences, more reliable). The seamless integration with pinions for the BAG motor, RS775, and RS550 alongside their perfectly chosen gear sizes (in 20, 40, 60, and 80 teeth) make it so that most any mechanism (especially intakes) can be powered off of one or two stages to get the perfect reduction.
These are a product I haven't seen widely used or known about that I feel would greatly help teams accomplish some of their more complex or weight-dependent design goals.
Why are these not available from vexpro.com and why are they all on backorder, stuff like this makes me nervous about planing to use them in season as much as I would love to try them out.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 29-04-2015, 04:09
Andrew Lawrence
Posts: n/a
Because they're from WCP, not VEXPro. RC would be the better person to ask, but as I understand it, the two only act as distributors of some of each other's products - they are still their own independent companies (hence why WCP only sells vexpro items and not vexiq or vrc things, and why VEX doesn't sell WCP gears and sensors, among other things).
I'm not too sure about the backorder status (once again RC is the person to ask). Emailing him is the best way of getting information that you don't know, and it seems so many people have questions but don't ask, so please do ask. I'm no official affiliate of the company, but I imagine it's hard for them to know what questions need answering and what could use some clarification if nobody asks them.
Unread 29-04-2015, 08:08
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Would love to see a 3/8 hex bore sprocket line come out for #25 chain. 1/2 hex is great but a lot of applications don't need a shaft that thick.
VP cim adapter was awesome. Will use them again in future years.
The vex pro line in general has helped our team become such a more competitive team.
Unread 29-04-2015, 12:58
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
We used tons of VexPro components this year. Everything worked flawlessly.
The only small request would be for the end of the 1/2" round output shaft for the VersaPlanetary to be drilled and tapped just like the 1/2" hex output shaft.
Unread 29-04-2015, 13:15
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Lots of positives for VEXPro this year.
Here are the improvements needed:
1) Further reduce costs of everything. Maybe make the versaplanetary ring gear segments out of nylon with an embedded aluminum ring gear.
2) All the hexes and versakey patterns need to be clocked the same! We had to cut a double sprocket in half to get a set of hex keyed sprockets keyed the same.
3) Inventories need to be increased. I'll forgive the omni and mecanum shortage this year, but gears and sprockets are going to be used every year, and shouldn't go out of stock. This may clash with comment 1, but I'd like to see an attempt at both.
Unread 29-04-2015, 13:31
Jared Russell's Avatar
Taking a year (mostly) off
Finding a source of by-the-foot 15mm wide, 5mm pitch HTD belting for our elevator was difficult, as (Out Of) Stock Drive Products failed us and we had to resort to calling various distributors around the country.
Unread 29-04-2015, 13:35
AdamHeard's Avatar
Lead Mentor
And a pony unicorn.
Unread 29-04-2015, 13:36
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We used a lot of VEXpro stuff -- hex bearings, sprockets, gears, pinions, hubs, mecanum wheels, hex shaft, chain, masterlinks, clamping gearboxes, VP's, shaft collars, spacers, clamping bearing blocks, cams, versaframe, gusset plates, bag motors. We also ordered a lot of omni wheels before we switched to mecanum. Definitely the vast majority of our robot budget went to Vex/The Robot Space.
4 competitions --> No item from VEXpro failed.
My only request would be to make the two top bolt holes for the clamping gearbox have a little more meat around the top on the motor insert side--the nut cradle stripped on one gearbox when the nut wasn't properly seated in the hole, and a little more nylon around the top of the cradle would help a lot to prevent that.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 29-04-2015, 13:41
Best Available Data
FRC #1778 (Chill Out!)
I imagine at least some supply issues were because of the labor disputes on the West Coast ports that gridlocked everyone's supply chain. Tying up cash in a large inventory for unlikely events like that is probably mutually exclusive with cheaper goodies.
Originally Posted by Conor Ryan
If VexPro had some items that would give teams flexibility in design without having to wait and see, it would be an incredible customer experience. IE - a gearbox speed sampler kit that will give me a variety of speeds .. snip..
What separates this from the existing Versaplanetaries? Buy a bunch of stages and mix and match to your heart's content.
Unread 29-04-2015, 13:57
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This and as Vexpro expands teams are using more and more and trying new things meaning more demand. Who knew we'd have elevators meaning a high demand for chains and sprockets for lifting.
Our team purchased an insane number of sprockets this year for 25 chain, something we've never used before but I think we ended up with close to 80 sprockets by the time we had what we needed and ordered for spares. Glad we were able to help a few teams at the Championship who needed 18t hex sprockets that ran out a long time ago.
Unread 29-04-2015, 14:01
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
There might not be a ton of demand for it (at least, other than my team), but will vex ever start selling 2 inch colson wheels with hex bore?
Unread 29-04-2015, 14:05
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Originally Posted by Conor Ryan View Post
I'm looking for reasonably priced packages that will help speed up the build season process (basically to take shipping out of the equation). If VexPro had some items that would give teams flexibility in design without having to wait and see, it would be an incredible customer experience. IE - a gearbox speed sampler kit that will give me a variety of speeds I can change in and out or a kit of Versaframe parts that will let me prototype manipulators easily. I'm more concerned about manipulator design than Drivetrain kits.
Vex knows what teams buy the most of. Commonly used ratios that give you range of power would be a good starting point for a VP starter kit.
A new teacher that just inherited a robotics team wouldn't know where to start with this process, thats why I'd like a preconfigured kit, of course I know you can just get a bunch of stuff now, I'm just lowering the bar.
Unread 29-04-2015, 14:21
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
I wonder if a dual ball bearing supported VP output option would be useful for teams. Pretty much every VP failure I've seen is from excessive combined loads and VPs are just one of those things that teams tend to abuse. Most industrial planetaries of similar size like the Neugart PLE series are dual ball-bearing supported from the factory.
2016: FRC 865 Mentor
