Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 30-04-2015, 13:47
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Help With Mecanum Drive
Originally Posted by Kitkat View Post
I am working on our program for just driving for next year. Does anyone have a sample of mecanum code so I can compare and figure out what I'm doing wrong?
Mecanum drive is what you're doing wrong
Just kidding, i believe there is a sample project in the wpilib Java library
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 30-04-2015, 14:01
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Language?
Also... If you want to set it up yourself you can use ether's math: http://www.chiefdelphi.com/media/papers/2390
(I believe the document you want is the "Mecanum Programming: Single and Double Joystick" but all of them are extremely helpful.)
We have used it the past 2 years, and it makes life simple for Field centric or Robot centric control.
Hope this helps.
Unread 30-04-2015, 16:38
Kitkat Kitkat is offline
FRC #3750 (Badger Gators)
Kitkat is an unknown quantity at this point
I'm using LABview not java
Unread 30-04-2015, 17:27
Darkseer54's Avatar
AKA: Zach Kaplan
Someone posted their labview code here: http://www.chiefdelphi.com/forums/sh...31&postcount=9
Unread 30-04-2015, 23:00
Canop3n3r's Avatar
Canop3n3r Canop3n3r is offline
AKA: Aaron Myers
FRC #2844 (Stampede Robotics)
Canop3n3r is an unknown quantity at this point
If you are using Labview then when you build a new RoboRio project you can select the template for a Mecanum Drive Robot. I dont know if you are wanting to go through the effort and write the code yourself but the template has given our team the purest strafing that we have ever had.
