Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Unread 25-04-2015, 12:31
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
[FTC]: Anderson Powerpole Question
Chief Delphi,
We had a question regarding the Anderson Powerpole Connectors (used to replace the unreliable Tamiya connectors). After following the instructions provided in the FTC Wiring Guide, we found that the connectors came apart really easily, and could just be pulled apart without any effort.
Is this supposed to happen? If not, how can we solve the problem?
Thanks,
Charging Champions
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 25-04-2015, 12:43
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: [FTC]: Anderson Powerpole Question
When you say "come apart" do you mean that the pins pull out of the shell? That's an indication that you haven't pushed the pins into the shell far enough.
If you mean that the two ends that mate come apart it means the pins are not in the shell the right way. There is a curve to them that applies the mating surface pressure.
What size are you using?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 26-04-2015, 14:06
We mean that the two ends that are supposed to connect to each other (e.g. the battery end and the charger end) do not click and can be pulled apart very easily.
Here is the link to the Powerpoles that we are using:
http://www.amazon.com/Anderson-Power...rson+Powerpole
How can we solve this problem? Is there some pin or clamping device that holds the two ends together?
Thanks,
Charging Champions
FTC Team #8660
Unread 27-04-2015, 00:34
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
They come with two pronged inserts to hold the plugs together... The slide in and as long as those stay in there is no way that the plugs can come undone.
Unread 27-04-2015, 00:36
FRC #4296
Here's an image of what I am talking about.
Unread 27-04-2015, 00:41
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
One of the other ways you can minimize disconnections is by securing your wiring using zip ties-- if you immobilize the wire on both sides of the connection, I've never seen the small powerpole connectors disconnect. If you're using them as a battery connection and securely fastening your battery (which you should be), you shouldn't encounter any significant issues. Treat your electronics nicely and they will treat you nicely back!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-04-2015, 20:38
Thanks to all for responding.
Chinske4296: We didn't receive those parts with our Anderson PowerPole kit. Can we buy them separately online?
Thanks,
Charging Champions
FTC Team #8660
Unread 01-05-2015, 08:45
JimInNJ JimInNJ is offline
AKA: Jim Bates
FTC #9765
JimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond repute
No, they aren't in the kit. Powerwerx stocks them. www.powerwerx.com
Unread 01-05-2015, 18:33
Thanks for posting.
FTC Team #8660
Unread 01-05-2015, 22:20
Team CC, what you describe is unusual for these connectors. We have used them for years on our FRC robots without resorting to the locking devices shown above or the other type manufactured by Anderson. Typically the friction alone holds them very tight. It really sounds like the contacts are not fully inserted in the shell. The metal of the contact should almost come out the front of the shell and there should be an audible 'click' when they are inserted properly. Does any part of the metal contact show at the back of the plastic shell?
Unread 02-05-2015, 08:09
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
I agree with what Al is saying. Can you post some pictures of you power poles as you have built them?
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 09-05-2015, 17:14
Sorry for the late response. Here some pictures of one of the Anderson PowerPoles we built, taken from various angles:
ID:	18980  Click image for larger version
ID:	18981  Click image for larger version
ID:	18982  Click image for larger version
ID:	18983  Click image for larger version
FTC Team #8660
Unread 09-05-2015, 17:56
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
You need to have the wires with the contacts in the connector for them to snap together. Without the wires with the contacts, they will slip in and out.
Check out the 4th picture down on this link showing the cutaway view of a connector. The metal bump shown at the end of the connector snaps over the other metal bump on the mating connector. That's what holds them together. Without those, they will slip in and out freely.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 10-05-2015, 00:40
Our problem is that the two connectors are not snapping together (the wire clicks into the connector without a problem).
One way to prevent the connectors from coming apart is to use the pronged inserts, as Chinske4296 was saying. Are the two connectors supposed to click together easily, or do we have to use the inserts mentioned above?
Thanks,
Charging Champions
FTC Team #8660
Unread 10-05-2015, 04:57
wgardner's Avatar
Can you show pictures of your connectors with the wires in them? Again, without the wires, they won't click together at all. They will only click together and be hard to pull apart once the wires are in place.
Some teams will push the wires with the pins into the connectors but not enough for the metalic crimped part to fully snap over the metal spring in the connector. If this snap hasn't happened, then the springs won't hold the two mated connectors together.
