Go to Post Remember that the 4-slot cRIO...only has 4 slots. :) - Alan Anderson [more]
Unread 30-04-2015, 09:41
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Cinnamon Toast is an unknown quantity at this point
Using an SPI Gyro
Hey guys,
In past years we haven't used many sensors to dictate any kind of drive control on the robot. For the most part we have always done tank drive on traction wheels or some combination of traction and omni wheels. This year we decided to have at it with an omni h drive. Moving to a little more maneuverability in our drive train made auton interesting. Using the h drive in auton often led to rotation of the whole chassis (due o the H drive not being centered perfectly combined with un equal weight distribution). The obvious way to fix this would be to use some type of gyro. I've played around with the KOP gyro and I'm not impressed. After a lot of calibration work and debugging, it still drifts way to much for my liking. After reading some of the other posts like this one,
http://www.chiefdelphi.com/forums/sh...d.php?t=130538
I think it would be a good idea to check out a gyro like the ADXRS450.
http://www.analog.com/en/products/me...-evaluationkit
I've run into a couple of problems though, most having to do with my knowledge base. First of all, I haven't worked with SPI before. From what I can tell, the gyro class that is normally used in C++ won't be applicable because initialization arguments require an analog in pin number. How would I go about wiring and programming such a gyro? Sorry in advance for my lack of knowledge in this subject, so if you guys could provide detailed help I would be grateful. I looked into using the SPI class but the notation says that it probably shouldn't be used directly, and it's just used by other devices. Thank you all in advance!
-Cinnamon Toast
Unread 30-04-2015, 14:23
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Using an SPI Gyro
As a collaborative effort with a few other teams, we've been working behind the scenes to put together a library for that specific sensor. Unfortunately it's only available in LabVIEW, but work is being done to port it over to C++/Java!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 01-05-2015, 13:06
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Originally Posted by Cinnamon Toast View Post
Hey guys,
-Cinnamon Toast
If you haven't already purchased the eval kit for the ADXRS450, please consider also the navX MXP. This was released since the original article you mention above, and is a plug-n-play sensor designed specifically for use w/the RoboRIO. It's a 9-axis sensor (3 gyros, 3 accelerometers, 3 magnetometers) with a motion processor, and it provides accurate, low-drift readings for use in driving straight, as well as field-centric drive. Hundreds of these boards are in use by FIRST FRC teams, and it includes libraries for LabView, Java and C++ as well as examples and other documentation.
Unread 01-05-2015, 18:05
I have not gone ahead and bought the ADXRS450 so I'll go ahead and take a look at that! Reading on the website though, it mentioned that the device plugs straight into the MXP port on the roborio. Is it possible to get an extension cord out of the MXP port so I can mount this device somewhere else in the robot? The roborio is at quite the awkward angle right now, and I believe it's actually butted against the battery when in operation. Thank you for the recommendation though!
-Cinnamon Toast
Unread 01-05-2015, 18:10
See https://code.google.com/p/navxmxp/wi...InstallOptions
Unread 01-05-2015, 18:34
http://www.andymark.com/product-p/am-2997.htm
Unread 01-05-2015, 22:18
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
We used the ADXRS453 this year and wrote a class in Java to interface with it.
I've described how to use the class in another thread on CD
See the post here: http://www.chiefdelphi.com/forums/sh...94&postcount=4
The port over to C++ should be pretty straight forward.
Feel free to contact me if you have any questions. james [at] team2168.org
http://team2168.org
