Go to Post So as you're thinking about this, think simple. - Cyberguy34000 [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 02-05-2015, 18:17
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: [FTC]: New Android Control System
Originally Posted by DavisDad View Post
Only 1 day after April
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #32   Spotlight this post!
Unread 09-05-2015, 08:28
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Jerry McManus has posted an excellent guide and also frequently asked questions (FAQ) post at the FTC forum:
Feeling overwhelmed? Start here.
Technology forum FAQ
Thanks Jerry! Great stuff!
  #33   Spotlight this post!
Unread 09-05-2015, 08:42
DavisDad's Avatar
MechE
Modern Robotics Inc. registration is up. I've registered and received an email with info below:
Welcome to Modern Robotics Inc.
Thank you for registering with Modern Robotics, Inc. When you are sign in to your account you will be able to check out the latest products and receive news updates as well easily place and track shipments.
Modern Robotics is proud to be working with FIRST and Qualcomm on the new FTC competition electronics control system for 2015 – 2016.
We are also partnering with MATRIX Robotics to supply the all new MATRIX FTC Competition Set for the 2015 – 2016 FTC season.
The new FTC Competition Set, endorsed by FIRST, features more than 750 parts and new larger “C” beams, new 12v battery and components, 4 all new 12v motors with built-in encoders, new metal gears and much more. MATRIX is the only true 3D building system that users find easy to build with and it promotes good engineering practices.
Take a look at MATRIX at http://www.modernroboticsinc.com/mat...ompetition-kit
In addition, all FTC teams registered with FIRST for the 2015 – 2016 season will receive discounts when ordering from www.modernroboitcsinc.com
  #34   Spotlight this post!
Unread 10-05-2015, 12:10
DavisDad's Avatar
MechE
This post is intended to summarize what is know about the new control system in order to plan work for next season.
I'm basing this mostly on posts with knowledgeable information at the Chief Delphi & FTC forums:
MattRain (Chief Delphi)
levydev (Chif Delphi)
Tom Eng, FTC Engineer (FTC)
Jerry McManus (FTC)
FTC Cause and Effect, FTC Staff (FTC)
ChiefCT
Thank you Matt, David, Tom, Jerry & JoAnn for your help in the forums! Much appreciated! Apologies to anyone I've missed.
FTC 2015/2016 Calendar
to be completed later...
  #35   Spotlight this post!
Unread 10-05-2015, 20:42
RecycledElectro's Avatar
RecycledElectro RecycledElectro is offline
KF5LMY
AKA: Andrew Allen
FTC #9810 (FTC #9810 & FLL #15602 (OCS Strike Eagles))
Rookie Year: 2015
RecycledElectro is an unknown quantity at this point
What I don't know:
As you posted later on, the Modern Robotics site (http://modernroboticsinc.com/) has a lot of this info. I am reposting it here to make it easier to find.
  1. How the Modern Robotics Inc. (MRI) components control information between the ZTE type phone and the robot's functions.
There is a MicroUSB to MiniUSB cable that connects the phone to the "Core Power Distribution Module." That module apparently acts as a PowerPole splitter and as a USB hub. It gives You access to 7 USB ports that can take the various MRI modules.
These modules connect with a USB-A-Male to MiniUSB cable. At first I wondered why they went with the (almost obsolete) MiniUSB connectors, but it makes sense. It will prevent wrong signals being fed into phones, which stop working once they loose their smoke.
Example code is on their web site.
  1. For off the shelf sensors, what are the signal inputs? They look like 3-pin analog.
The "Core Device Interface Module" seems to support everything: 8 digital I/O, 8 analog in, 2 analog out, 2 PWM out, and an I2C bus with 6 drops run to pins. They do not state any reason why we can not use more than one of these if we wish.
http://modernroboticsinc.com/core-de...terface-module
Andrew
  #36   Spotlight this post!
Unread 11-05-2015, 08:08
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
I didn't find it. Can you give a link?
FTC 4137 "Islandbots"
islandbots.org
  #37   Spotlight this post!
Unread 12-05-2015, 20:58
DavisDad's Avatar
MechE
Continued from post #34 (with edits)
  • September 12- FTC 2015/2016 Kickoff
My rest of the school year plan as mentor:
  1. Figure out the Android controls and what components will be usable for 2016 season (e.g.: are only ZTE Speed phones allowed, or can we use a tablet for the driver interface)
  2. Learn the App Inventor and Android Studio systems. Be able to help the team set up their programming environment (AI and/or Java).
  3. When the Software Development Kit (SDK) for the Android and Modern Robotics controls goes public this month (May), I hope to be able to figure out how all the components work together and move the programming environment set-up forward.
  4. Since our team has limited financial resources, I want to figure out what is required to buy through FTC kits and what can be purchased more cheaply. I've already bought 2 used ZTE Speed phones on eBay, a USB hub & some USB-OTG cables for experimenting. I paid about $90 for the lot, and the FTC Kit costs $268.
  5. Be prepared to understand and leverage the forum posts from programmers about Java Studio, App Inventor and the other computer stuff. Hopefully I'll have a test-bed programming environment assembled to allow testing the information supplied by folks knowledge about the implementation details. I know this will be difficult for our team as I'm the most knowledgeable person about programming, and I don't know much. I'm hoping if I can smooth the path by understanding enough to guide the students so they can do the semicolon coding.
I've gotten the phone to link with "Wi-Fi direct", gotten "Hello World" programs to work on a ZTE (both Android Studio & App Inventor). I'm now working on getting a game controller hooked up to the driver phone and send something to the robot phone; I'm thinking a button press on the Logitech would initiate the "Hello World" program on the robot phone.
  #38   Spotlight this post!
Unread 13-05-2015, 02:02
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
  • September 5 (guess)- FTC 2015/2016 Kickoff
  1. Since our team has limited financial resources, I want to figure out what is required to buy through FTC kits and what can be purchased more cheaply. I've already bought 2 used ZTE Speed phones on eBay, a USB hub & some USB-OTG cables for experimenting. I paid about $90 for the lot, and the FTC Kit costs $268.
Kickoff is September 12th.
When doing through the registration process, you HAVE to buy one of the "control" sets, lowest one is $10 and includes a cable, hub and binder. We bought our phones through Best buy for 40 a pop, at 4 phones (2 teams). So it looks like you will have to spend another 10 dollars.
I'm currently making multiple different ZTE Phone mounts that will connect to Tetrix and Actobotics easily that I will release to everyone that has a 3d printer.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
  #39   Spotlight this post!
Unread 16-05-2015, 23:31
DavisDad's Avatar
MechE
There are a lot of posts posts being added to the FTC forum that help with the new controls. Below are links of searches on posts by people I've found helpful.
Tom Eng (FTC Engineer): http://ftcforum.usfirst.org/member.php?95868-Tom-Eng
Jonathan Berling (Qualcomm Engineer): http://ftcforum.usfirst.org/member.p...nathan-Berling
PlilBot (Coach 2818): http://ftcforum.usfirst.org/member.php?5560-Philbot
Cheer4FTC (Mentor): http://ftcforum.usfirst.org/member.php?91071-Cheer4FTC
  #40   Spotlight this post!
Unread 18-05-2015, 08:45
capnrmorgan's Avatar
capnrmorgan capnrmorgan is offline
FTC6934 FLL307 FRC1882 VEX/FVC2012
AKA: Rich Morgan
FTC #6934 (The TranSisters)
capnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to beholdcapnrmorgan is a splendid one to behold
Quick guide to setting up a ZTE Speed phone for FTC from GEARSInc.
Shows how to configure the phone, and install the Android Debug Bridge (ADB) driver on your PC.
FTC 6934 (Pilot) FVC21/2021, 2015 - FTC Connect Award - NJ State Qualifier Participant, 2006-2007 4th place VEX Competition Quarterfinalist, 2005 National Championship Atlanta VEX-21 Think Award Nominee - FVC21
FLL 307 Gear Girls, Electro Llamas, Bio-hazzard,... 2009 FLL Robot Design Award GSJS Rowan Qualifier, DE FIRST State Participant, 2008 Teamwork Award Rowan Qualifier, DE FIRST State Participant - Bio-hazard
FRC 1882 Rebel Robotics (former) 2006 and 2007 NASA Growth Grant, 2005 Winners of Duel on the Delaware Thanks 75 and 222 Pre Rookie FRC (Thanks Team 25), 2005 Montclair Mayhem 2nd place seed (Quarter finalists), 2005 Rising Star Award (Tiki) Brunswick Eruption (12th place and Quarter finalists)
JrFLL NJ Spring Expo Coordinator
FIRST DJ/MC at NJ FTC States, Qualifiers and events
Girl Scouts of the Jersey Shore FIRST Robotics
  #41   Spotlight this post!
Unread 18-05-2015, 20:27
DavisDad's Avatar
MechE
Robert Van Hoose (Mentor): http://ftcforum.usfirst.org/showthre...ll=1#post13288
  #42   Spotlight this post!
Unread 18-05-2015, 21:46
DavisDad's Avatar
MechE
From Tom Eng here: http://ftcforum.usfirst.org/showthre...ll=1#post13747
Hi Folks,
We plan on releasing the apps and the SDK soon. You can configure the robot to have a null hardware configuration (no hardware modules attached) and if you have the SDK, even though you don't have the hardware yet, you can still write some basic op modes and test things like the telemetry function (you can send data back from the robot controller to the driver station) and learn how to select and run an op mode.
Tom
  #43   Spotlight this post!
Unread 19-05-2015, 11:13
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Thanks for keeping this thread updated! Super helpful to those of us that forget to check the FTC Forums all of the time
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #44   Spotlight this post!
Unread 20-05-2015, 21:58
DavisDad's Avatar
MechE
Tom Eng at the FTC forum has posted an excellent video demonstrating the new controls at Youtube: Demo Video
  #45   Spotlight this post!
Unread 21-05-2015, 10:01
levydev levydev is offline
FRC #0116
levydev is an unknown quantity at this point
Anyone with a ZTE Speed device? I'm trying to use mine as a Wifi-Only device but it continues to try to activate on the cell service. At least I think that is what is happening.
Getting interrupts dialogs like:
"Activate Device: Are you swapping this device for one you currently have on your account?"
and
"The network did not respond in time. The sim card has locked. Please powercylce the device"
