Go to Post I love how the people of Chief Delphi can turn a spam post into a somewhat non-timewasting thread. Either way, congrats CD and thanks for this ;) - logank013 [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 04-05-2015, 15:16
koreamaniac101's Avatar
koreamaniac101 koreamaniac101 is offline
Founder and Team Leader
AKA: Soohan Kim
FRC #5938 (Razor Steel Robotics 4-H Club)
Rookie Year: 2016
koreamaniac101 is an unknown quantity at this point
Post Uses of a Machine Shop and Equipment
Hi, I'm the founder of my robotics team that plans to start its rookie year in 2016. We just got access to our local universities machine shop with:
  • Lathe
  • CNC Mill
  • Vertical/Horizontal Bandsaw
  • Cold Saw
  • Surface grinder
  • Drill Press
My new mentors are wondering why would need all the machine shop equipment for. Could any give specific examples of what you would use each of these equipment for? If you could link pictures of specific parts made from a Mill or Lathe, that would be great too.
Unread 04-05-2015, 15:25
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
FRC #1086 (Blue Cheese)
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
Re: Uses of a Machine Shop and Equipment
We use our lathe to make shafts for our custom gearboxes, intakes, and elevator roller assemblies this year. The lathe was only really necessary to cut the grooves for retaining rings. We used a mill to make our elevator rails (which we could have used a drill press for) and our intakes, which had weight reduction hole patterns and slots for the motor to mount to so it was easier to tension chain. I can upload pictures or CAD files of the parts later today.
Unread 04-05-2015, 15:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Find mentors who know how to use the equipment - they'll also know what it can and can't be used for. The first place to look for mentors is right there at the machine shop - who runs the shop? Who uses it already? See if you can arrange some classes in using the equipment.
At an abstract level, with this sort of equipment and the knowledge of how to use it, you should be able to build components and subsystems and systems that fit together in clean, robust, and lightweight fashion. For many teams (my own included), match drilling pieces is sometimes the highest precision we can achieve.
Your biggest problem with all this equipment is likely to be the desire to use it just because you can - spending dozens or hundreds of hours on an item that's not significantly better than a COTS item.
Unread 04-05-2015, 15:39
MrRoboSteve MrRoboSteve is online now
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
You'll use these two a lot:
Drill Press
Band saw/cold saw
This is very useful, but many teams get by without it:
Lathe
Less useful, but many teams get by without it:
CNC mill
Not commonly used in my experience:
surface grinder (typically use a bench disc sander instead)
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 04-05-2015, 15:40
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Does the CNC mill listed have a motorized rotary table or manual indexer?
There can be overlap with CNC capability between mills and lathes depending on how many accessories are on them.
For example live tooling and sub-spindles on a CNC lathe verus a vertical mill with a rotary table.
Unread 04-05-2015, 15:45
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Alright, here's what I've got:
CNC mills are beautiful for sheet metal fabrication, if you have someone who is willing to cad.
Lathes can be used to shave material off of axles/shafts that are too wide. They can also be used to tap or drill holes into axles/shafts.
Horizontal/vertical band saws are mainly used to make simple cuts (i.e.. Cutting channel to length, making simple sheet metal/polycarbonate components, etc.)
Drill presses are good for making holes that don't have to be very precise (prototype parts, for example)
Surface grinders can be used to remove sharp edges/burs from material that has been cut
Cold saws (from what I understand) are basically fancy chop saws, which can be used to cut material (channel, HDPE blocks) to length.
Unread 04-05-2015, 15:48
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I like this point. Yes, it's great to have these tools, but one has to justify whether it would be better to use COTS than custom-made. We have to consider more than just the cost of the materials -- yes, custom broaching or milling or turning can save money, but you have to consider the "cost" of training your students to perform these tasks, the actual amount of time it takes to turn around one of these tasks, the time needed to make spares in case something breaks in competition, etc.
I've learned that there are many advantages of using COTS, and I intend to put a much larger focus on using COTS parts (including the KoP drive frame, if possible) next year to reduce build time.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 04-05-2015, 15:50
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Why would you use cnc mills for sheet metal fabrication? Cnc lasers/routers and water jets are way more suitable for sheet metal fabrication.
You'd rather use the cnc mill for stuff like tubing and solid milled parts.
R.C.
MadTown Robotics Team 1323
Unread 04-05-2015, 15:57
Andy A. Andy A. is offline
Getting old
FRC #0095
  • Lathe
  • CNC Mill
  • Cold Saw
  • Surface grinder
  • Drill Press
Hi-
All those tools are very relevant during a FRC build season.
Specific examples;
Turning spacers for drive train use on a lathes seems to be the most common part we turn. We'll also use the tail stock to drill and/or broach perfectly concentric holes; obviously a critical feature for rotating components. Yeah, there are other ways to do this, but the lathe is almost always the best tool for it.
We (team 95) will often use a CNC plasma cutter to 'blank' brackets and side plates, and a bridgeport style CNC mill to cut tighter tolerence features like bearing pockets, hole patterns etc.
the mill is also useful for making brackets in thicker materials; these parts (on the vice) were done on a manual mill, but could have just as easily been done on the CNC. They required a lot of material removal and a couple of loose tolerance fits. hogging that material out with hand drills, hack saws or making the parts out of several pieces would have been a huge pain.
CNC mills are great for repetitive parts. These bars were done on a CNC mill. Each feature had some tightish tolerances, and doing them all 'by hand' on a manual mill with DRO just wouldn't be reasonable.
The other tooling, like bandsaws, drill presses and cold/chop saws are so basic in our build process that I don't think we've bothered documenting their use much. They're indispensable.
Take a look at the Robot Showcase sub-forum, in particular dig around for 'build threads', where teams detail the build process for their robots. They often have good photos and discussion of parts being made. All the photos I've used are from the Team 95 Hard at Work threads from the 2014/15 seasons.
Unread 04-05-2015, 16:07
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
What R.C. said - waterjet, laser, router all make more sense for sheet metal parts.
Lathes are basically manual CNC mills. They can also be used as very precise drill presses.
No - lathes are lathes. Mills are mills. There is some small overlap, but they do very different tasks.
No - you're better off with a deburring tool or sander. Surface grinders are common in machine shops, but I struggle to think of where they would be necessary for FRC. They're used to create very smooth, and flat surfaces - often at very tight tolerances.
They're normally designed to cut ferrous material, normally at slow (<100 RPM) speeds. More or less a chop saw for steel or hard materials. Less than optimal for cutting aluminum, but they'll work.
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 04-05-2015, 16:12
I am assuming that they don't have a laser/water jet cutting sponsor and that they only have access to what they have in shop.
Unread 04-05-2015, 16:16
Lasers and waterjet cutters are not on the list of available machines.
Unread 04-05-2015, 16:19
Okay, now I realize my mistake... *facepalms at my stupidity*
I fixed my original comment.
Unread 04-05-2015, 16:26
Kevin Sheridan's Avatar
Kevin Sheridan Kevin Sheridan is offline
Kevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond reputeKevin Sheridan has a reputation beyond repute
Thats why RC recommended using the CNC mill for tubing and solid parts
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
  • Lathe
  • CNC Mill
  • Cold Saw
  • Surface grinder
  • Drill Press
CONGRATS!! and thank you for starting a new team! It's not easy to get sponsors with machine shop and have access to machines. I am sure many newer teams feel this pain.
All these machines are great, not just of robotics, for anyone who wants to pursue engineering. Some of our team members who have graduated have an advantage when they join college clubs, they breeze in the workshop training and a step ahead of the crowd in automation and building. Our team has the basic drill press, hand held power tools and small bandsaws and we are managing with them. Just think of a student who learns (or trained) on CNC? Its not what you can do with the machine to build a robot, its one's imagination and perseverance to design and build something. I am sure students will find ways to use these machines.
