Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 02-05-2015, 20:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: PBL-104: Planetary Ballshifter
Unread 02-05-2015, 20:16
Andrew Lawrence
Posts: n/a
Re: pic: PBL-104: Planetary Ballshifter
Very nice. Lightening pattern seems conservative in some places, but that's not a bad thing. The use of a module gear is a nice touch as well. Only question is how will it mount to a frame, but I'm sure I'm just not seeing it.
Your designs are getting a lot better - keep up the great work!
Unread 02-05-2015, 21:21
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The standoffs that hold the gearbox together are 10-32 tapped, so you can just screw the plates on. The front view of the gearbox shows these are countersunk, but that's because I wanted a single style of plate to work for both sides (in real life you would just not countersink the front side).
The module gear is because there are no good diametrical pitch gears available.
Thank you!
Also, I forgot to mention that the weight is 1.6lbs as shown, which can be reduced by lightening the 60t gear.
Unread 02-05-2015, 22:46
LCJ's Avatar
LCJ LCJ is offline
AKA: Lewis Jones
FRC #2468 (Team Appreciate)
Team Role: CAD
LCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really nice
Beautiful.
Is the sprocket sandwiched between the planetary gear set and the motor output? It looks like the sprocket's face is being attached straight to the planetary gear plate?
Really, really cool design!
Unread 03-05-2015, 01:09
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Originally Posted by LCJ View Post
Beautiful.
Pretty much. The sprocket is attached to a custom versahub, which acts as a carrier plate for the planetary gearset and can be shifted into to skip the 3:1 reduction from the sun gear to the carrier plate.
Unread 03-05-2015, 05:36
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
That's not a swerve drive!
But seriously,
Beautiful.
It really is.
I see that part, but I don't see how the sprockets actually attach to the custom versahub, at first I thought the pins that held the planet gears in went all the way through the bolt pattern on the sprocket, but thats not it, so?...
Also, I would recommend these guys for the standoffs between the 2 plates, you can hold them with a wrench which is better than hoping it they don't start spinning after a 1/4 turn of the bolt.
I would also try to include mounting holes for an encoder somewhere, maybe the front face. Remember to think about manufacturing method for the plates, I see the CIM boss is set at 0.750, probably won't fit an actual CIM if you use a water jet...but I have no idea if you're actually planning on making one of these
Again, very cool.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 03-05-2015, 07:18
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
But seriously,
It really is.
Again, very cool.
Thanks for reminding me to put mounting holes for sprockets; I actually forgot about those. Right now there are only holes for the planet gears.
Hex standoffs sound good too. Usually I would just tighten both sides at once, but I guess that's not possible if it's mounted on a face already.
Usually I use 0.752 for cims, but I guess I got lazy there. Generally a plunge with a 3/4" endmill takes it out to just the right size.
Forgot about encoders, and yeah, I'll probably stick those on the front face. Alternatively I could put the encoder in the back and put the shifting part in the front, but it remains to be seen.
The day when we buy a CNC I'm going to be experimenting so much...
Unread 04-05-2015, 11:29
MStump's Avatar
MStump MStump is offline
AKA: Michael Stump
FRC #3309 (Friarbots)
MStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to behold
Looks cool! Where would you plan to get your 5" wheels from? The standard ones from Andymark and VEXPro are normally 3.5, 4, 6, or 8. I would definitely be interested to see a solid 5" COTS wheel because that opens up the world to a lot more possible ratios.
Michael Stump
FRC Team 3309 Friarbots
Mentor 2015-Present
Student 2011-2015
Unread 04-05-2015, 11:30
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Colson makes 5" Performa wheels, sold by banebots here:
http://banebots.com/pc/WHB-COLSON/TP2P-506SS-S3
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 04-05-2015, 19:08
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
You can get 5" colsons from robotmarketplace, or banebots as stated above.
Because this doesn't direct drive a wheel from the main shaft (although theoretically you could adapt it to do so) you can place the gearbox in a remote area on one side of your chassis and run 3" or 2.5" wheels.
Unread 04-05-2015, 19:32
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
How do you plan on getting the ring gear? Do you plan to make it yourself or do you have a source for one that you can purchase?
Unread 04-05-2015, 19:49
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
QTC sells part # KSI1-60, which is a 60 tooth 1 Module ring gear. However, it is heavily modified to add mounting holes and remove most of the steel around the enndges.
If you have a CNC it's not too bad of a modification.
Unread 04-05-2015, 22:45
MStump's Avatar
AKA: Michael Stump
Cool thanks! Yeah not direct driving any wheels gives you a lot more breathing room for ground clearance for sure.
Michael Stump
Mentor 2015-Present
Student 2011-2015
Unread 04-05-2015, 23:36
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Are the two sprockets in the STEP file intentional?
How about getting the output to the end of gear box too?
Any kind of bearings/bushings in the planetary gears? That part reminds me of an Andymark GEM gearbox which brings back bad memories of bag-n-tag day 2013.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 05-05-2015, 00:06
nathannfm's Avatar
AKA: Nathan
FRC #3940
I don't think you understand how it is designed to work, the sprockets ARE the output. You would have 2 chains running out of the gearbox to 2 of the 3-4 wheels per side of the robot, which would also have double sprockets on them and be chained to the other wheel or 2.
