Go to Post and as you can see, all rumor threads lead to silly, loads of silly - JaneYoung [more]
Unread 05-05-2015, 00:50
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: PBL-104: Planetary Ballshifter
Originally Posted by nathannfm View Post
I don't think you understand how it is designed to work, the sprockets ARE the output. You would have 2 chains running out of the gearbox to 2 of the 3-4 wheels per side of the robot, which would also have double sprockets on them and be chained to the other wheel or 2.
Pretty much. For that reason this is a less-than-optimal gearbox for anything that is cantilevered, as you waste weight on the extra sprockets.
An output on the main shaft is tricky, as it always spins at a 5:1 ratio from the cims if you use 12t pinions. The sprockets wiill change speed when shifted, but not the main shaft.
In order to have an output on it, the sprockets would have to be put on another versahub which is attached to another shaft that is coaxial with the main shaft. Kind of a pain, and there's no way to do it while remaining within a couple pounds.
Unread 05-05-2015, 01:07
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Could you replace the 2 sprockets with a gear and put another shaft underneath the whole thing with a 1:1 gear (or not 1:1 if you don't want) and have a cantilevered output that way?
Not super necessary or elegant, but I don't see why it wouldn't work.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 05-05-2015, 01:14
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The point of this was to reduce weight and keep the single-shaft design; by adding a large gear and a second shaft it loses both of those advantages unfortunately. If I had to make a 2-shaft gearbox I would just make a regular ballshifter (like ABS-101, although I would probably increase the primary reduction if I were to go that route; that gearbox went a tad too fast for most).
