Go to Post Bottom line is I love FIRST and what it stand for. Hold nationals in a corn field on old crates and I'll support it! If the FIRST staff is reading, Thank you for all the hard work you do! - Gene F [more]
Unread 03-05-2015, 17:06
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Sheet Metal Fabrication vs. Using Channel
I have seen both used before, I just want to know if one is in any way better than the other. Or just the benefits of using one over the other.
Unread 03-05-2015, 17:09
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Sheet Metal Fabrication vs. Using Channel
We've used sheet metal for a couple small parts.
It lets you cheesehole like crazy to get rid of material that doesn't really help strength anyway if a sponsor does it. Channel is faster to source though.
Unread 03-05-2015, 17:25
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
It really is dependent on many factors: resources, time, designing capabilities, experience, etc. WildStang has recently worked with two sheet metal manufactures to make parts for our robots. This year, our bot was almost entirely sheet metal, apart from most parts on our lift. Channel is useful for many things, you just need to use it right. I'm not going to get into much detail about this, or start a war. You may want to look at older threads that explain pros and cons of both.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 03-05-2015, 17:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The best way is using the resources at your disposal. Both require different design methodology, but both will get the job done.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-05-2015, 17:54
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
For the last 6 years our drive train was c-channel. We have done one and two level chassises for complex designs.
The channel is quick to put together snap together, easy to mount to(just need to make spacers for the inside so it clod rant get pinched), and not all to heavy.(can always still wide holes to take out weight)
We may switch to sheet metal or tube design chassis next year if we can get access to the cnc machine.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 03-05-2015, 18:08
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
The biggest difference is that most teams using C-channel or other extrusions are typically doing most of the individual part fabrication inhouse, where most teams that do primarily sheet metal construction have their parts produced in partnership with an external sponsor. This is a very different approach to fabrication, and it works very well with certain resource sets (and not well at all with others). I wrote at length about the process, and why our team uses it, here.
Unread 03-05-2015, 20:00
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Your post that you linked is really great. On a similar note, how do you get your students interested in CAD? It's one thing that I think could help us greatly but no one wants to implement it.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 04-05-2015, 11:37
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
A 3D printer really helps here. There is just something about drawing something in CAD, then holding it in your hand a short time later.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 04-05-2015, 22:12
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
Do you do large scale 3-D printing? Or just small stuff? I know of a team that 3-D printed a whole chassis with carbon fiber and fiberglass infused filament on an 8 foot by 8 foot printer platform.
Unread 04-05-2015, 22:42
MStump's Avatar
MStump MStump is offline
AKA: Michael Stump
FRC #3309 (Friarbots)
MStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to behold
Do you know what team that was? Because that sounds awesome and I want to figure out how they managed to get the resources for that haha.
Michael Stump
FRC Team 3309 Friarbots
Mentor 2015-Present
Student 2011-2015
Unread 04-05-2015, 23:37
Lead Bumper Mentor
AKA: Mike Marandola
The team is 3824. They discuss the process in this thread. Here are their robots from 2012 and 2013. They are really awesome.
Unread 05-05-2015, 01:31
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
Sheet metal frames allow you have a much lighter but equally strong chassy/robot compared to slotted tube, however sheet metal is harder to fabricate (bending it correctly) and can be dented easer, though i would definitely use sheet metal if i ever get the chance.
also note that by making the base out of sheet metal you have also move the robot/s center of mass much higher, thus making it more flip prone.
Unread 05-05-2015, 01:34
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Why would you have to move the COM higher?
Unread 05-05-2015, 02:14
Active Alumni
when reducing weight of your foundation you cause it's COM to be to a heavier side, so if i take weight off the bottom and add it to the top i now have a pendulum
it's due to that fact that your weight lemit is 120 so by reduce your chassie weight by 20 pound and now you added it to the top of the robot, you will be more likely to have more mass at the top of the robot and is more likely to tip/flip
if this needs further explanation I'll reply when it's not 2:14 AM lol
Unread 05-05-2015, 08:04
I can only see this being a problem if you have a tall robot (above 60" or so)
