Go to Post ...several people have told my that my brain has been oxygen-starved since at least 1975. - dlavery [more]
Go Back   Chief Delphi > Competition > Championship Event
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 05-05-2015, 09:34
Re: Motion Planning and Control for FRC - FIRST Championship Conference Session
Originally Posted by mman1506 View Post
Just you
Originally Posted by Asymons View Post
Both links work for me perfectly.
I can view the presentation on-line. Is that what you both are referring to?
I am saying that the PDF and PPTX download options in this popup menu do not work for me:
http://i.imgur.com/jWPsNVP.png
Jared, is that intentional or an oversight?
  #32   Spotlight this post!
Unread 05-05-2015, 14:28
Jared Russell's Avatar
Taking a year (mostly) off
Not intentional. The PDF and PPT links work for me.
I've attached the PDF.
File Type: pdf Motion Planning and Control for FRC.pdf (3.61 MB, 450 views)
  #33   Spotlight this post!
Unread 05-05-2015, 15:43
Thank you.
  #34   Spotlight this post!
Unread 07-05-2015, 12:48
chsahit's Avatar
chsahit chsahit is offline
Lead Developer
AKA: Sahit C
FRC #0011 (MORT)
chsahit will become famous soon enoughchsahit will become famous soon enough
What does the spline paramater represent? When discussing 2d hermite cubic spline fits functions are created in terms of "s". Is this time?
Thank you and great presentation!
  #35   Spotlight this post!
Unread 07-05-2015, 13:23
artK artK is offline
Just Another Person
AKA: Art Kalb
no team (No Team)
artK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond reputeartK has a reputation beyond repute
Spline parameters can be whatever you want: time, % of time, % of total arclength. When 254 implemented it in 2014, I believe we used % of total arclength. As long as you're consistent with your parameter usage, the code should be mostly the same.
Art Kalb
Team 254 (2011-2014): Head Scout, Programmer
2011, 2014 World Champions
  #36   Spotlight this post!
Unread 07-05-2015, 20:00
Usually 's' is not time; it is just an arbitrary parameter (nominally varying between 0 and 1 for any given segment). You can reparameterize a spline by creating another function that maps 's' to something else, like time or arc length.
In other words, instead of looking up your position by calling a function x(s), you would call x(s(t)), or x(s(arc_length)).
Note that if you are creative, you can formulate the problem in different ways. In 2014, 254 actually created 2D splines by making a single function y(x). In this case, the 's' parameter was actually the x coordinate (shifted and rotated to the origin for each spline segment). There are some pros and cons to doing it this way as opposed to the more common parametric way (where you create two independent splines for x and y).
  #37   Spotlight this post!
Unread 16-10-2015, 19:42
apache8080 apache8080 is offline
Lead Programmer, Drive Coach, Scout
AKA: Rishi Desai
FRC #5677
apache8080 is on a distinguished road
How does 254 generate the trapezoidal curve for the velocity? My assumption is you just set motor speed to max(1.0) and then calculate what the velocity is at specific time intervals until it reaches a cruise velocity. Then I guess you derive the acceleration from that velocity graph. This makes sense but where I get confused is the deceleration because if you just set the drive speed in the code to 0 then since the motor controllers are in brake mode the motors will just stop.
I am a newbie when it comes to motion profiling so these questions may seem a little dumb.
Thanks for all the help.
  #38   Spotlight this post!
Unread 21-10-2015, 01:25
You never want to run saturated (full PWM output). The math to handle that with a drivetrain properly is very nasty due to the non-holonomic nature of a skid steer robot and coupled dynamics.
The correct solution is to pick a velocity and acceleration for your profile such that you never run saturated while driving. For 971's 2015 robot, we used 2 m/s as the peak speed and 3 m/s^2 as the acceleration. That results in very clean motion for us which doesn't saturate.
I would suggest verifying this by picking a velocity and acceleration for your profile, driving the profile with a robot, and then plotting the PWM value requested. You should never see a request above 1.0 or below -1.0.
  #39   Spotlight this post!
Unread 24-10-2015, 10:47
ranlevinstein's Avatar
ranlevinstein ranlevinstein is offline
FRC #2230 (General Angels)
ranlevinstein will become famous soon enough
Hi,
1. during autonomous why did you apply control only to the speed and rotation of the drivetrain wheels? there are other options like DFL or IOSFL and I was wondering why you didn't choose an option with regulation for the robot's absolute position and and heading.
2. Can someone from 971 please explain how did they use integral control and how to tune the gains matrices for LQR? also in your auto, did you use LQR for the trajectory? if so can you explain how you did that?
You can read more about DFL, IOSFL and posture regulation in this slideshow:http://www.dis.uniroma1.it/~deluca/r...ingControl.pdf
Any help will be greatly appreciated
  #40   Spotlight this post!
Unread 24-10-2015, 10:54
Hi,
  #41   Spotlight this post!
Unread 31-12-2015, 12:43
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
As promised, here is the recording of the session (in standard Cheesy Poof 4k of course): https://youtu.be/8319J1BEHwM
This was a wonderful presentation!
You made mention that the Talon SRX's can do a lot of "this" for you and that it is extensively documented. Are you just referring to the Feedback/Feedforward PID control built in to the Talons or can they execute a full trajectory/path? I have searched through the software manual for the Talon SRX (http://www.ctr-electronics.com/Talon%20SRX%20Software%20Reference%20Manual.pdf
) and didn't find any mention of motion planning/trajectories.
Looking through the source for CANTalon in WPILib I do see mention of trajectories and motion profiles. Is there additional documentation somewhere that I am missing that actually talks about using motion profiles?
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
  #42   Spotlight this post!
Unread 31-12-2015, 12:51
Volunteer, WPILib Contributor
no team (Waiting for 2021)
The motion profile stuff is being added this offseason to the CAN Talons. The documentation for it should be released at kickoff.
Team 4488 - Mentor 2013-2016
