Go to Post To paraphrase a common answer from the GDC: There is no rule that explicitly forbids this. - MechEng83 [more]
Unread 05-05-2015, 11:58
Abhishek R Abhishek R is offline
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Sheet Metal Fabrication vs. Using Channel
Originally Posted by cad321 View Post
All he is saying is that if you take weight from the chassis and put it into a system that is even half an inch higher, you have raised your COM. Depending on your robots design, this may not be an issue.
Well, yes, but you could just lose the weight completely and not even put it into a different system. You would just end up with a lighter robot in general.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 05-05-2015, 12:21
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
...and then, if you are concerned about being at maximum weight (perhaps you want to maximize traction) you have the ability to put additional weight exactly where you want it to create the best result.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
