Go to Post The person that I would, without a doubt, would like to meet the most is my sanity. - lukevanoort [more]
Unread 05-05-2015, 18:53
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
USB Serial Port
Our team will be switching to Java from Labview over the summer so I went digging into WPILIBJ and saw that you could initialize the serial port as the RS-232, MXP UART, or the USB. To my knowledge you couldn't use USB in Labview.
http://first.wpi.edu/FRC/roborio/rel...1 _1Port.html
Has anyone used this? Can you chose which USB port?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 05-05-2015, 22:43
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: USB Serial Port
In order to do this you have to use a Usb to serial adapter. And it will recognize the serial port.
Unread 12-08-2015, 13:38
Re: USB Serial Port
A little late, but here's a version of the LabVIEW serial port open that supports the first USB serial device.
Java and C++ kUSB only support the first USB serial device.
