Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 06-05-2015, 15:29
stu54 stu54 is offline
None #2458
stu54 is an unknown quantity at this point
RS-232 Port Problem
I am trying to use the RS-232 port. I do have console out turned off in the NI web-based tool. Here is my init code in the constructor:
serial = new SerialPort( 9600, SerialPort.Port.kOnboard );
Then in my loop in operatorControl() I have:
String ss = serial.readString();
And that causes this trace on the driver station console:
ERROR Unhandled exception: java.lang.RuntimeException: Code: -1073807298. HAL - VISA: General IO Error at [edu.wpi.first.wpilibj.hal.HALUtil.checkStatus(HALU til.java:48), edu.wpi.first.wpilibj.SerialPort.getBytesReceived( SerialPort.java:326), ...
I get the same traceback even if I have nothing connected to the
RS-232 port.
Any ideas?
Unread 06-05-2015, 15:41
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: RS-232 Port Problem
I don't have time to check on it now, but you may be colliding with a predefined object named serial. Changing the name of the object to something more specific (e.g. my232port) can quickly determine if this is the issue; if you get the same error, that wasn't it.
Unread 07-05-2015, 10:35
None #2458
Looks like the problem is the data being transmitted. Loopback on RS-232 works fine. I am trying to read the ASCII put out by a Max Sonar but I am
guessing the syntax violates the VISA standard that the serial ports rely on so
the code crashes. I also tried the MXP port with the same results. (I did have a TTL-to-RS232 adapter when I tried the RS-232 port).
Unread 07-05-2015, 14:31
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I had done a longer post this morning - not sure where it went.
Have you tried serial.reset()? I would suggest this immediately after the constructor.
You might also try manually calling serial.getBytesReceived() to see if it returns zero, an error, or something else.
Have you tried getting an error message from HALUtil? I'm not familiar with the HAL subsystem, and I was surprised to see it coming from a serial port; I suppose that the USB is somewhere behind the HAL system. The following should return a string that might prove enlightening:
edu.wpi.first.wpilibj.hal.HALUtil.getHALstrerror()
