Go to Post However, the best responses come with patience. It might be a couple of days before you get a good answer or it could be 10 minutes. - Molten [more]
Unread 06-05-2015, 18:03
Andrew Lawrence
Posts: n/a
How would you design "Not Recycle Rush"?
This is just something of my own curiosity that I thought I'd ask the community about. If you were to design your own FRC game with some of the same design constraints as Recycle Rush (ie. Robots built for RR could play new game with little to no modification), what would it be? How would you use some of the already existing aspects of the current game to make a more enjoyable new one?
This is all hypothetical of course, but it's a thought that's come up that seems like an interesting question to ask others.
Unread 06-05-2015, 18:10
AdamHeard's Avatar
Lead Mentor
Re: How would you design "Not Recycle Rush"?
I don't know what I'd do exactly, it's hard to make a balanced split field game.
I do however know that I prefer the Vex game, Clean Sweep, to Recycle Rush.
https://www.youtube.com/watch?v=lBnLxyzKqtI
Unread 06-05-2015, 18:12
pokelogan89's Avatar
pokelogan89 pokelogan89 is offline
Logan Schorr
AKA: Logan Schorr
FRC #1086 (Blue Cheese)
pokelogan89 can only hope to improve
Maybe something you could do is merge it with Stack Attack a little bit i.e. get rid of the step, and the alliance with the most points still scored wins (or you could keep averages.) So instead of just building stacks, you build them and defend them. This will add an aspect of defense to the game not previously had, thus making the game a little bit more "enjoyable."
Unread 06-05-2015, 18:31
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Take the 2011 field minus the minibot towers. Place a scoring platform where the 2011 scoring areas were. Same for HP stations. Keep the 2015 step/landfill but cut off the ~3 feet near the field boundary (may have to move cans in). 2015 scoring rules rules but 2011 gameplay rules (can't touch opponents in their scoring zone or lane, etc). Not sure what you could do with auton but if the staging zones were rotated 90 degrees, you could probably have a very similar setup.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 06-05-2015, 18:48
LCJ's Avatar
LCJ LCJ is offline
AKA: Lewis Jones
FRC #2468 (Team Appreciate)
Team Role: CAD
LCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really nice
Less totes in the landfill and human player stations and no more step, but teams can't descore stacks. Stacks now have to be scored on the platforms on the opposing side of the field to count towards your score.
Now the robots compete to control as many stacks from the landfill as possible while trying to prevent the opposing robots from getting across the field to score.
Unread 06-05-2015, 19:03
JDGallagher's Avatar
JDGallagher JDGallagher is offline
AKA: John Gallagher
JDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of lightJDGallagher is a glorious beacon of light
Divide the field into three zones on a flat open field, similar to Aerial Assist. Human player feeder stations are on either side of the white zone. Alliances' scoring platforms are in their respective colored zones. Each alliance is not allowed to enter the opposing alliance's colored zone.
Unread 06-05-2015, 19:04
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Basically this, but get rid of the step, and replace it with totes. Then teams can fight over the landfill sorta but stacks are safe in the endzone.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 06-05-2015, 20:41
My variant would be to remove, or lower, some section of the step (like that open area in the middle), or maybe all of it. Replace with tape. Coopertition stays.
Then: The scoring platform closest to the alliance station is protected. Contact by an opposing robot or anything under its control is penalized (using the descoring rule from this year, single penalty if no descoring happens). But the OTHER platform, the one farther away, is NOT protected. It is, however, worth double the points!
Good luck strategizing that one...mwahahahaha!
Unread 06-05-2015, 20:47
AKA: John Gallagher
Maybe make it protected in the last ~3 seconds of the match?
Unread 06-05-2015, 21:00
I was thinking some medium-weight bonus for having all alliance robots in the auto or staging zones myself. Maybe about a 3-stack with noodled can. Let the protection take care of itself...
Unread 06-05-2015, 21:05
FRC #0624
Everyone in the staging zones is a cool idea...
Team Website
Unread 06-05-2015, 21:19
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Allow for individual points in autonomous, but build for more than one:
2pts - 4pts - 8pts for 1, 2, 3 robots
4pts - 8pts - 16pts - 32pts for 1,2,3,3 stack totes
6pts - 12pts - 24pts for 1,2,3 containers.
Eliminate litter throwing and allow multiple litter scores per container - but only one per container put in by human player.
Robots have to "clear a path" to containers on the step before grabbing them (can not "reach" over a tote).
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 06-05-2015, 21:52
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Because of the design of robots this year it would be unreasonable to introduce defence. Even then drastic changes would change the game too much. Peoples designed their robots around recycle rush, not the other way around. That said...
Yellow totes act like 4pt grey totes after auto.
Flip the grey totes near the step.
Remove chute door.
Litter not in an RC is meaningless. Throwing is a foul.
A grey tote scored in auto is worth 2pts plus it's level. (autonomous landfill stacking)
Both alliances start with an extra green bin they can place anywhere on their side of the field.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 07-05-2015, 15:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In keeping with the "recycle" theme, made it more valuable to process litter than to cast it. This would also have encouraged some noodle manipulators. How about another "white" can in the middle of the field, and each noodle delivered there is also six points?
Downplayed or eliminated the canburglar arms race. The IRI rule that each side may not contact the RCs on their left side during auto is certainly one good way to do it.
Make the inverted totes and totes on the step valuable enough to provide a good race during teleop.
  • I know this won't be popular with a lot of teams, but the easiest way to do this would be to reduce the number of totes available via HP stations, and possibly to reduce to one or zero HP stations. That is, starve top teams for totes just as much as for RCs.
  • Another possibility along these lines would be to eliminate the step, and provide a "white zone" in the middle where robots of either alliance may enter during teleop, and where most of the RCs and totes start. Of course, you'd need bumpers and would eliminate tetherbots, which was a neat departure for the year. Maybe this would lead to separate "extractor" and "stacker" designs.
Unread 07-05-2015, 16:00
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
Maybe leave it unprotected, but have stacks there score over time (some amount of points every 5 seconds). This makes them immediately a focal point of the match as soon as they're placed, provides no benefit for last minute stack toppling (super unsatisfying to watch), and provides a benefit for holding a stack for a long time.
However, this could easily get boring before long, so it should probably have a maximum point value reached after ~20 seconds. This value would need to be high enough to make it beneficial to go for this instead of just building another stack. In the end I'd see mid-range teams going for this more, while the top-tier teams would be able to build non-bonus stacks fast enough to outweigh the bonus. I'd like a bit of strategic diversity in the game, rather than everybody doing exactly the same thing every match.
Also, if you open up the game to defense, we'll need to have a penalty for parking on the opponents' scoring platforms to block scoring. Something in line with the pinning rules would work, so you could still drive on them and block for a short time.
