Thread Tools |
Rating:
Display Modes |
Re: How would you design "Not Recycle Rush"?
My variant would be to remove, or lower, some section of the step (like that open area in the middle), or maybe all of it. Replace with tape. Coopertition stays.
Then: The scoring platform closest to the alliance station is protected. Contact by an opposing robot or anything under its control is penalized (using the descoring rule from this year, single penalty if no descoring happens). But the OTHER platform, the one farther away, is NOT protected. It is, however, worth double the points! Good luck strategizing that one...mwahahahaha! |
Maybe make it protected in the last ~3 seconds of the match?
I was thinking some medium-weight bonus for having all alliance robots in the auto or staging zones myself. Maybe about a 3-stack with noodled can. Let the protection take care of itself...
Everyone in the staging zones is a cool idea...
Allow for individual points in autonomous, but build for more than one:
2pts - 4pts - 8pts for 1, 2, 3 robots 4pts - 8pts - 16pts - 32pts for 1,2,3,3 stack totes 6pts - 12pts - 24pts for 1,2,3 containers. Eliminate litter throwing and allow multiple litter scores per container - but only one per container put in by human player. Robots have to "clear a path" to containers on the step before grabbing them (can not "reach" over a tote). |
Because of the design of robots this year it would be unreasonable to introduce defence. Even then drastic changes would change the game too much. Peoples designed their robots around recycle rush, not the other way around. That said...
Yellow totes act like 4pt grey totes after auto. Flip the grey totes near the step. Remove chute door. Litter not in an RC is meaningless. Throwing is a foul. A grey tote scored in auto is worth 2pts plus it's level. (autonomous landfill stacking) Both alliances start with an extra green bin they can place anywhere on their side of the field. Last edited by Scott Kozutsky : 06-05-2015 at 21:55. |
#7
In keeping with the "recycle" theme, made it more valuable to process litter than to cast it. This would also have encouraged some noodle manipulators. How about another "white" can in the middle of the field, and each noodle delivered there is also six points?
Downplayed or eliminated the canburglar arms race. The IRI rule that each side may not contact the RCs on their left side during auto is certainly one good way to do it. Make the inverted totes and totes on the step valuable enough to provide a good race during teleop.
#8
However, this could easily get boring before long, so it should probably have a maximum point value reached after ~20 seconds. This value would need to be high enough to make it beneficial to go for this instead of just building another stack. In the end I'd see mid-range teams going for this more, while the top-tier teams would be able to build non-bonus stacks fast enough to outweigh the bonus. I'd like a bit of strategic diversity in the game, rather than everybody doing exactly the same thing every match. Also, if you open up the game to defense, we'll need to have a penalty for parking on the opponents' scoring platforms to block scoring. Something in line with the pinning rules would work, so you could still drive on them and block for a short time. |
