Go to Post I think they get nutrition from chain greese. - Lucid [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #35   Spotlight this post!
Unread 06-05-2015, 23:29
amannababanana amannababanana is offline
FRC #1678
amannababanana is an unknown quantity at this point
Re: Not to jinx next year, but...
This is what I want for next year:
2 fields, 2 robots: robot on one field shoots balls, robot on the other field intakes the balls and passes them over a wall to the other robot. Both robots have to balance an inverted pendulum, and if it falls, the robot gets disabled for 5 seconds. The "balls" contain motors that activate randomly, so they can move around by themselves. Minibots on the field follow lines on the field, and can crash into the robots to make the pendulum fall over. There are 5 types of balls and 4 goals, and each counts negative if scored into the wrong goal. However, one type of ball changes color every 2 seconds, and must be scored at the right time. Did I mention that it is on a lunacy floor?
