Thread Tools |
Rating:
Display Modes |
Re: Kiwi Drive Concept
What is the benefit of putting the wheels at such an angle? I wouldn't assume omnis are designed to handle that much loading at that angle. And it looks like it would add a lot more difficulty for the machining?
Is it a shock system to help guarantee that all wheels are touching the floor? |
In general, three wheels will always be touching the floor no matter what angle they are at. The two reasons I see for using the nearly flat angle are 1) it lowers the center of mass, and 2) it moves the contact point outward just a little more from the center of the robot.
For #2, this could also be done by putting the motors inboard of the wheels; the wheels could be just a fraction of an inch from the outer frame. |
The entire frame is riding lower when the omni wheels are sideways. Also there are more omni rollers in contact with the ground when they are sideways as opposed to when the ground is tangent to the wheel.
The biggest issue is the one Wayne presented - wheels weren't meant to be loaded that direction. Omnis probably even more so - the whole point of omnis is that they don't exert a force parallel to the shaft. As a result, sound engineering would tend to reduce the sustainable force parallel to the shaft in favor of other requirements. |
#7
Also, it would require a lot less machining to mount the feet on pneumatic cylinders (though you'd still have to harden them against lateral forces, perhaps with a pipe-within-a-pipe), and hard-mount the wheels. Whichever you actuate, moving the feet close to the where the wheels contact the carpet will decrease the vertical travel required to reliably switch.
#9
Looking a little closer - what are those cans inboard of the gearboxes (one of them is partially obscured by the signal light)? If those are pneumatic cylinders, perhaps these raise the robot and lower the wheels to the floor?
Hmm, and there seems to be a foot midway along the short face of the frame. Is there some reason that you want to "raise the landing gear" and be stationary? Thinking up names for that - how about a kizzy drive? It sounds close enough to kiwi, and those of you who remember the Roots miniseries a few decades ago may recall that kizzy means "stay put". |
#10
The idea is that each omni wheel can be retracted independently, giving the robot the ability to change its center of rotation about each pivot point. There's also the advantage of retracting all omni wheels when in scoring position so the robot becomes difficult to move. |
#11
...Kinematic calculations are left as an exercise for the student...
#12
Ironic that you say that just as I'm leaving my last dynamics class of the year... but I agree!
#13
This happened to many of the robots with Mechanum and Omni... compared to those robots, they were slightly more successful, simply because their triangle design was hard to push, but at the same time, they were pretty easy to spin
#15
I wonder how useful the ability to plant itself would be for the kizzy drive? Would this added ability combined with shifting its center of turn make up for the low traction inherent to all omni/mecanum drives?
