Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 07-05-2015, 18:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Kiwi Drive Concept
I skipped the research when I realized that all of the square roots and trig functions canceled out, and the mapping was pretty straightforward. To map rotation about a point xr, yr at angular speed wr (measured in radians/second, with rotation from the positive x axis towards the positive y axis being a positive angular speed) to translation speed vx,vy and rotation w0:
w0 = wr
vx = w yr
vy = -w xr
you can use this same preliminary mapping to make a mecanum drive rotate around a desired point.
For conversion purposes, 1 radian per second is 30/pi ~ 9.55 rpm.
Using the WPIlib convention for your coordinate system (+x to the right, +y forward, rotations clockwise as viewed from above), your angular speeds will be reversed from this, and you will need to use:
w0 = wr
vx = -w yr
vy = w xr
Last edited by GeeTwo : 08-05-2015 at 12:29. Reason: Added navigation convention paragraph and transformation
Unread 08-05-2015, 11:41
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
w0 = wr
vx = w yr
vy = -w xr
If you use mathematical conventions for your coordinate system (+x to the right, +y forward), and measure your rotations with the navigation convention of clockwise as viewed from above, your angular speeds will be reversed from this, and you will need to use:
w0 = wr
vx = -w yr
vy = w xr
Thanks a ton for all the information about kiwi drives! It has definitely influenced my plans moving forward!
Unread 08-05-2015, 22:30
w0 = wr
vx = -w yr
vy = w xr
Once you've got Vx (strafe right speed), Vy (forward speed), and ω,
the inverse kinematics for your 3 wheel tangential speeds are:
S1 = r*ω + Vx
S2 = r*ω - 0.5*Vx - 0.866*Vy
S3 = r*ω - 0.5*Vx + 0.866*Vy
(see attached sketch)
Name:	Kiwi inverse kinematics.png
Unread 10-05-2015, 10:43
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Combining the two transformations, to rotate an equilateral kiwi drive around a pivot point (xp, yp) with angular speed ω, the inverse kinematics using Ether's diagram above are:
S1 = ω * (r - yp)
S2 = ω * (r + 0.5*yp - 0.866*xp)
S3 = ω * (r + 0.5*yp + 0.866*xp)
Checking rotation points to verify that we didn't swap sign conventions along the way:
(0,0): all are ωr, check
(0,r): S1 = 0, S2 = S3 = 1.5ωr, reasonable
(0,2r): S1 = -ωr, S2 = S3 = 2ωr, reasonable
(0,-2r): S1 = 3ωr, S2 = S3 = 0, check
(1.155r, 0): S1 = ωr, S2 = 0, S3 = 2ωr, ok
(-1.155r, 0): S1 = ωr, S2 = 2ωr, S3 = 0, ok
If you want "forward" to be directly between wheels rather than through one (for example if you'll be picking up pieces or doing an internal stack), rotate the robot 180 degrees, leaving the axes and forward arrow in place. Then, the inverse kinematics for rotation about (xp, yp) become:
S1 = ω * (r + yp)
S2 = ω * (r - 0.5*yp + 0.866*xp)
S3 = ω * (r - 0.5*yp - 0.866*xp)
