Go to Post I told people that I was a summit for world leaders for our regional. We had two that are current world leaders and over 1000 that will be ones in 2029. - Foster [more]
Unread 07-05-2015, 23:43
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Small CIM in wheel swerve
Unread 07-05-2015, 23:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Small CIM in wheel swerve
4.6lbs per module? I think you've finally made a swerve that can be lighter than a WCD.
Much applause.
Is the two-plate design lighter than just flipping the motor over and using a planetary gearbox?
EDIT: Is that a custom gear on the bottom?
DOUBLEEDIT: Oh wait, MiniCIM. Dang, that was almost the dream.
Unread 08-05-2015, 00:13
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Are you certain your materials are set correctly? A mini CIM weighs 2.16lbs according to VEX. If they are set correctly and that is in fact how light the module is, than I must say, very impressive.
Unread 08-05-2015, 01:26
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Much applause.
Thank you. This was mostly a design experiment for me, but I suppose it could be useful in a game like this year where a lot of weight is needed for the manipulators, and maneuverability is important, but pushing power is not.
i'm not sure about lighter, but I thought it would be a shame to put such a tall gearbox on such a short swerve module.
Yes. Several of the gears are custom so it would require access to a good laser, water jet, or wire EDM.
Yep...
Maybe one day.
Thank you, the mini CIM is accounted for, at 2.16 lbs. I'm pretty sure that the materials are correct, but like I said, there are some details that aren't in the CAD.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 08-05-2015, 05:30
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
What motors turning the left right motion? Pg or 750 maybe?
Unread 08-05-2015, 11:25
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
In the CAD, it is an AM-912, but in reality, I would probably use a banebots RS 550.
Unread 08-05-2015, 13:42
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you used a worm gear for steering, it seems to me that you could orient both motors horizontally and get the module height down to the wheel diameter. You'd also save some weight on a second gear stage at a bit of loss of steering efficiency. You'd need slip rings for the drive motor since you couldn't run the wire out through the rotation hub, which might eat up the weight savings.
Also, what is the light colored gear to the lower right of the main rendering? I don't see what else it engages, and I also don't see it in the reflection.
Unread 08-05-2015, 13:46
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
Great work, would you be willing to share STEP files so we could take a look?
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 08-05-2015, 14:59
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
From the looks of the reflection, I would say that it's paired with another pinion underneath the bottom support plate via a live axle, which in turn is what engages the great big ring gear that goes around the perimeter of the module.
That makes for a 3-stage reduction in total, so I am inclined to agree that a worm gear would be a viable option here.
Unread 08-05-2015, 15:33
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Thanks, Skywalkar - I see it now. The reflection plane must be tilted down as it approaches the viewpoint (or the vertical on the module is tilted away at the top). I thought it strange that the dark gray gear did not engage with anything except to pass through to the yellow gear below the lower plate.
Unread 08-05-2015, 20:11
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Bryce,
Really nice concept once again.
Are you using a Silver Thin Bearing to support the the pivot assembly?
The planetary drive inside the wheel is a great idea, are there two stages there for ~9x reduction?
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 09-05-2015, 09:54
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by InFlight View Post
Bryce,
This is what I'm most curious about, what kind of speeds are to going to get out of these? I'm sure there's an encoder mount somewhere, but where is it? Very, very impressive design.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 09-05-2015, 12:02
InFlight's Avatar
AKA: Jim
With a large steering gear like that you can't use an absoule encoder.
Team 141 at championships had a similar large steering gear setup. They used an incremental encoder to count steering input revs, but also had a pivot extension that triggered a proximity switch to calibrate the nominal forward position. Really elegant and beautifully machined swerve drive. They used a Kaydon brand bearing, very similar to the Silverthin ones. I had the pleasure of talking with the 141 students and mentor for quite a while, really an exceptional team.
Unread 09-05-2015, 12:52
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
It appears there's an absolute encoder on the top of the entire module, likely connected by bent polycarb like 2451 and 3928 before them.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 09-05-2015, 13:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
On 696, we had a large 84T 20DP steering gear, and a 1:3.5 ratio between that and our MA3 absolute encoder. That is, the steering encoder would pass through 3.5 rotations for every one rotation of the swerve module. We had to physically set the wheels pointing straight at the start of each match (which is probably good practice anyhow), and there was a good bit of math and code involved, but we were able to very reliably track the position of our wheels at all times, resulting in fine control and operation.
Was it easy or friendly to do it this way? No. Is it possible? Yes. Would we run anything other than a 1:1 ratio to an absolute encoder again? Maybe not. It's kind of a pain. We likely will look into using a zeroing sensor and incremental encoder next time if we cannot maintain a 1:1 ratio with an absolute encoder.
