Go to Post OMG this topic again. Those who stir the pot should lick the spoon. - nuggetsyl [more]
Unread 10-05-2015, 14:11
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
pic: Multipurpose Test Platform
Unread 10-05-2015, 14:17
bigbeezy's Avatar
AKA: Bryan
Re: pic: Multipurpose Test Platform
I have renders for the other versions but didn't want to clog up chief with a bunch of similar pictures
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 10-05-2015, 14:18
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
why dont you make an album on imgur or on a similar site and post the link here? i bet a lot of people (including myself) would want to see.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 10-05-2015, 14:22
bigbeezy's Avatar
AKA: Bryan
good call. http://imgur.com/a/feTUF/all
without the belts it may be hard to see. The middle axle (for the 6WD) is powered by the near motor. That belt would always be attached. The middle 2 wheels for the 8WD config are direct driven. A belt then powers the outer axle. The swerve wheels are just above the ground when using the other configs.
Unread 10-05-2015, 14:49
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
This is really really cool!
Unread 10-05-2015, 15:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We are also interested in having a pre-built test platform with several different drive styles. We didn't really consider a design with swerve, though we were interested in most of the others. We opted to go the opposite route, to build a bunch of different platforms that were all the same size with the same mount points, which would allow us to prototype a manipulator set and drop it onto any of our drive platforms. Later, we decided that it would be even easier to just have some chassis kits on the shelf and build them to our needs.
Unread 10-05-2015, 16:56
Connor McBride's Avatar
Connor McBride Connor McBride is offline
I live my life 2:30 at a time!
FRC #0166 (Chop Shop)
Connor McBride will become famous soon enough
This is really cool! Keep up the good work!
FRC 166
2013: mechanical
2014: mechanical, design, human player
2015: mechanical, design, CAD, Driver
2016: ???
Unread 10-05-2015, 17:00
bigbeezy's Avatar
AKA: Bryan
Could you expand on your chassis kits? Do you have precut material and mounting hardware? Did you use it this year and if so how'd it work?
Unread 10-05-2015, 19:34
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Seems like it lacks an intake bar. This would be a marvelous Week 1 platform to use with prototyping intakes for a game piece.
On that note, it'll probably need a front/rear bumper...
Unread 10-05-2015, 21:08
Rkant14's Avatar
Rkant14 Rkant14 is offline
AKA: Rahul Kantesaria
Rkant14 is an unknown quantity at this point
Great idea! This can be really useful to test various strategies for a particular game.
Unread 10-05-2015, 21:23
bigbeezy's Avatar
AKA: Bryan
wasn't intended to incorporate an intake. now you could modify where the swerve modules mount to allow you to mount an intake.
Unread 10-05-2015, 22:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
For this build season, it was the KoP AM14U2. Given that we're not up to swerve drive ability, we can build it out as mecanum, omni tank, 6, and 8 wheel drive with minimal cutting. We were also able to make some mounting brackets to convert it to an H drive. While it wasn't as fast as having completed chassis on the shelf, we were able to build each (except the H) in about a Saturday session. This was fast enough that by the time the "working prototype" lift frame was together, one of the drive chassis was ready to go with H-drive, and the other was complete as an omni tank and on its way to being an H-drive.
For 2016, we're looking seriously at using vex versaframe and their gearboxes and shifters, which should allow us to build any of these chassis styles with customizable dimensions and gear ratios and even shifting in only a little more time.
Unread 10-05-2015, 22:15
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
What is the purpose of putting the mounting point of the swerve modules so high? It seems to add unnecessary complexity to the frame.
Wouldn't it be simpler to run the framing straight across?
Please post again if this gets built.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 10-05-2015, 22:24
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
I think it's so that when there are no wheels on the side rails, the swerve is contacting the ground. However, when wheels are added to the axles on the side, the swerve is lifted slightly off the ground for some clearance so that the side wheels are the ones doing the driving.
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 10-05-2015, 23:19
bigbeezy's Avatar
AKA: Bryan
Exactly. The original goal is to have a single platform that programming can use to test out control systems for the various drive systems. With the swerve where it is you don't have to remove the module to switch back to tank drive. Just add wheels. I do like the ideas of modifying it to more easily incorporate additional features.
