Go to Post But FIRST isn't FRC anymore. We need to make way for FTC and FLL. - Tetraman [more]
Unread 10-05-2015, 17:49
Aaron Ng's Avatar
Aaron Ng Aaron Ng is offline
FRC #4159 (Cardinalbotics)
Team Role: CAD
Aaron Ng is on a distinguished road
Team 4159 Dual Cim Two Speed Swerve
This is the fourth iteration of our swerve module that we have designed, and the first one that we are planning to build and test during the off season.
Specs:
(JVN calculator’s) theoretical speed: (with 1 CIM + 1 miniCIM)
4.93 feet per second low, 14.78 feet per second high.
with a simple gear swap, we can get 6.08 feet per second low, 18.25 feet per second high.
Wheel Diameter:
2.5 inch colson default, can swap for a 3 inch colson.
Size:
5.125 in x 5.125 in x 12.6 in
2.25 in ground clearance
Weight:
approximately 10-11lbs
Steering:
bag motor versaplanetary at 1-50 ratio plus 30-60 gear reduction for a total of 1-100 reduction for a theoretical 90 degree turn speed of .12 seconds (courtesy of JVN Calculator)
Encoders:
-Steering: US Digital MA3 absolute encoder from Andymark, geared 1-1 to wheel rotation
-Wheel: US Digital S4 incremental encoder, currently randomly geared on the side to make life hell for our programmers.
We thank the internet for inspiration:
Andymark’s Swerve and Steer,
Team 221’s Wild Swerve and Revolution Pro,
Every Swerve on Chief Delphi,
Name:	test swerve render 1.JPG
ID:	18987  Click image for larger version
Name:	test swerve render 2.JPG
ID:	18988  Click image for larger version
Name:	test swerve render 3.JPG
ID:	18989  Click image for larger version
Name:	test swerve render 4.JPG
ID:	18990  Click image for larger version
Name:	test swerve render 5.JPG
Unread 10-05-2015, 17:55
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Team 4159 Dual Cim Two Speed Swerve
As a programmer, yeah, I know that feel
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 10-05-2015, 18:22
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks really good, and that weight is a very healthy one.
Why are you using standoffs to attach teh palte to the 2x1?
Why dog shifter over ball shifter?
Unread 10-05-2015, 18:41
Chak Chak is offline
AKA: Thomas
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
We're using standoffs/spacers to attach to the 2x1 frame because
- the steering gear goes between the spacers on top of the 2x1 below the bottom gearbox plate. You can see it on the third render, bottom right corner.
- It gives us 2.25'' ground clearance instead of 3.25''
-It allows us to put nuts between the bottom gearbox plate and the 2x1, which lets us remove the top gearbox plate independently for gearbox repair
We're using dog shifter simply because we have some parts already in stock, and because we haven't discovered a definite answer on CD about whether ball or dog shifters are better. Aaron has tried another version using ball shifter, but only saved 0.5'' in height, which we agreed was not worth buying new parts.
Unread 10-05-2015, 23:08
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Please tell me we can print red and blue spacers and switch them for different colored alliances. Please
Unread 11-05-2015, 00:23
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Is your steering encoder gear aluminium? If you have access to a 3D-Printer you could make it Nylon or ABS (not that it saves much weight).
(2015-?): 973
(2012-2015): 955
Unread 11-05-2015, 00:39
Chris is me's Avatar
AKA: Pinecone
Looks good.
Two biggest things:
1. Can you make the side plate modules thicker than 1/8"? I'd be concerned about how rigid those plates would be relative to each other, as any flex is going to lead to the bevel gears misaligning, and dramatically increasing tooth load as a result. It's not fun.
2. I think you could probably incorporate the 2x1 tubing into the gearbox design. It seems a bit weird to me that you have a gearbox full of 2" standoffs mounted right above a 2" tall tube. With some design tweaks, I bet you could use the 2" tube itself as the gearbox standoff, which will cut down on part count and weight (particularly bolt weight).
Unread 11-05-2015, 01:32
AKA: Thomas
Team Role: CAD
The absolute encoder gear is aluminum from sdp-si, the incremental encoder gear is steel from andymark. I'd rather not use steel, but the andymark one is convenient.
I suppose we can 3D-print gears if we tried, but as you said, it's not really that much lighter considering they're 1/8'' thick. Besides, the sdp-si gears we're using have something called clamp type hub, and it looks nice and easy for encoders. You can kind of see it on the 5th render.
So this is a common problem? Thicker plates it is. 3/16'' maybe. What would you suggest?
If that's a real concern, we could also extend the 3/8'' shaft and put retaining rings on both sides, so the shaft becomes structural and helps the plate out.
hmmmm...
I guess this would be a alternative trade-off we would make during competition season: less weight and simplicity versus more machining and less ease of gearbox repair.
Thanks for the idea! We didn't even realize that the spacers are almost exactly 2'' long, since we let them grow with the gearbox.
Only if you're willing to switch them every other match, Dylan.
Besides, most likely the spacers will be black/white delrin/nylon/aluminum standoffs. The spacers are taking more of a load this time around. The spacers are just blue on the CAD to differentiate them from all the other white/black parts.
Unread 11-05-2015, 09:36
AKA: Pinecone
It happens sometimes. It's one of the mechanical "gotchas" that makes swerve way harder than it looks; along with the coaxial shaft bearing support, path planning, etc.
My gut (note: my gut isn't a substitute for actual engineering) says 3/16" would be fine. I believe that is what the Robonauts Revolution module uses among others. It helps that you've added standoffs between your two reductions; you're clearly thinking about this sort of thing.
I don't think switching to retaining rings on both sides of the 3/8 shaft would make it much more rigid. You can't really use a live axle structurally without loading up your bearings. That said, it's probably more rigid than not doing it, but also probably not worth the effort.
The easiest way to add in rigidity for "free" is to make the output shaft a dead axle, but obviously with very small wheels a dead axle isn't really an option.
hmmmm...
Yeah, this certainly isn't something you HAVE to do, and it would probably require a lot of rearrangement to make it work, but it would result in a very rigid, solid gearbox for even less weight than your current setup. You could use a few standoffs on the other two sides to hold the gearbox loosely together on the shelf, then clamp it down around (and bolt through) the tube when you're mounting it.
Another thing: if you tuck your steering gear totally underneath the 2x1 and have the VP output drop down from above, you can use a steering gear much larger than your module and it can overlap the 2x1 tube somewhat, maybe letting you push the module a smidge further out the frame. This is getting a bit ridiculous though, and isn't worth a whole redesign.
