Go to Post Admiring the new chassis: "Oooo, nerd bling!" - Rick TYler [more]
Unread 09-05-2015, 23:02
tahmid0517's Avatar
tahmid0517 tahmid0517 is offline
AKA: Tahmid Sheikh
FRC #5036 (The Robo Devils)
Rookie Year: 2015
tahmid0517 is an unknown quantity at this point
Help with Eclipse in Linux?
I followed all the steps on the WPI page to to get started wih FRC Java Programming,including installing all the development tools and the FRC plugin, but when I go to create a project, I don't have the option of creating a WPI Robot Project.
Unread 10-05-2015, 00:05
bludeath's Avatar
bludeath bludeath is offline
AKA: Gabriel Finke
FRC #4565 (Skyline Coyotes)
bludeath is a jewel in the roughbludeath is a jewel in the roughbludeath is a jewel in the rough
Re: Help with Eclipse in Linux?
What version of Linux are you running? I'm personally running Ubuntu 14.04 with eclipse along with the java plugin.
Unread 10-05-2015, 14:21
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Hi! What version of Linux do you use? I'm running RHEL and it is working fine for me. I had some issues getting familiar with Eclipse but none like the one you are describing. What steps do you take to create a new robot project? (Aka what do you click on in your quest to make a new robot Java project)
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
Unread 10-05-2015, 14:35
tahmid0517's Avatar
AKA: Tahmid Sheikh
Rookie Year: 2015
I'm using elementary os. I click on new>project to create a new project but I don't get the option of creating a robot project. I get the option creating a java project but not a wpi robot project.
Unread 10-05-2015, 14:42
Autonomous Queen
Click on new, then project, then Other, which will bring up a window. Scroll down and maximise the WPI Robot Java window, then click on Robot Java Project.
Unread 10-05-2015, 15:27
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
I have Eclipse/WPILib installed on Ubuntu and also on Elementary OS. Both work fine for me.
My first guess is that the plugin didn't install correctly. Plugin installation should have created a directory in your home directory called "wpilib". Also, try going to the Help menu and selecting "Installation Details", which will pop up a dialog window. Under the "Installed Software" tab, you should see "Robot Java Development". If "wpilib" or "Robot Java Development" are missing, you should revisit the installation procedure.
Unread 11-05-2015, 06:27
AverageGuy AverageGuy is offline
AKA: Jim Lynch
FRC #4080 (Reboot)
AverageGuy is an unknown quantity at this point
When I click on File/New/Project I see the following in Eclipse Luna:
If you don't then I agree that for some reason your plugin didn't install correctly.
Jim
Unread 08-08-2015, 20:12
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
Click File > New > Other > (WPILib Robot Java Deveopment) > Robot Java Project
Not just Project. Also, ctrl+n should get you there.
