Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 12-05-2015, 09:48
philso philso is offline
FRC #2587
Re: Using the TI LaunchPad from your KoP
It seems that for the USB interface, I could use the USB interface (FTDI2232H) that is already on the LP and connects to the JTAG port and an SCI port on the TMS320F28069. It also seems that if I remove/open JP1 and JP3, the USB interface would "float" and be powered from the host computer.
Thanks for the recommendation for RealTerm. It would be a great way to get started. Later, I would still want to implement some sort of Visual Basic or Visual C program running on the host to set operation modes and monitor progress in a way that is more user friendly.
  #62   Spotlight this post!
Unread 05-03-2016, 15:15
Pugsly Pugsly is offline
FRC #1370
Pugsly is an unknown quantity at this point
Regarding the "Set Output" of the joystick I am trying to light up an indicator using the Launchpad that was included in last years kit and I can't for the life of me figure out how to wire this up in Labview.
So say for instance I want to light a LED on the launchpad Red or Blue depending on what alliance we are on. Anyone have any ideas on how do do that?
  #63   Spotlight this post!
Unread 05-03-2016, 19:07
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
How do you have it wired up to the LaunchPad? Do you have one red LED and one blue LED, or an RGB LED, or some kind of addressable LED strip?
I posted a few examples of how to use the WPI_JoystickSetOutputs.vi in a thread here. You can use the output from the Get Alliance.vi to select a different value for the output vi.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
