Go to Post Some people use Autodesk, some SolidWorks, some Pro-E, but 772 rose to the call of an unconventional CAD language, Minecraft. - Walter Deitzler [more]
Unread 12-05-2015, 18:24
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Joysticks not reading
I am reprogramming our 2014 robot, and the joysticks will not read in the code. However, the DS USB port tab does read the values properly. I have also tried multiple different controllers to no avail. This is using the pre-2015 control system.
Robot.java
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.IterativeRobot;
public class Robot extends IterativeRobot {
    Joystick driveStick;
    public void robotInit() {
        Storage.createObjects();
        driveStick = new Joystick(1);
    public void autonomousPeriodic() {
    public void teleopInit() {
    public void teleopPeriodic() {
        System.out.println(driveStick.getRawAxis(4));
    public void testPeriodic() {
Storage.java
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
public class Storage {
    public static Talon leftTalon1, leftTalon2, rightTalon1, rightTalon2;
    public static RobotDrive drive;
    public static void createObjects() {
        leftTalon1 = new Talon(RobotMap.LEFT_TALON_1);
        leftTalon2 = new Talon(RobotMap.LEFT_TALON_2);
        rightTalon1 = new Talon(RobotMap.RIGHT_TALON_1);
        rightTalon2 = new Talon(RobotMap.RIGHT_TALON_2);
        drive = new RobotDrive(leftTalon1, leftTalon2, rightTalon1, rightTalon2);
        drive.setSafetyEnabled(true);
RobotMap.java
public class RobotMap {
    public final static int LEFT_TALON_1 = 3;
    public final static int LEFT_TALON_2 = 4;
    public final static int RIGHT_TALON_1 = 1;
    public final static int RIGHT_TALON_2 = 2;
    public final static int LEFT_INTAKE = 7;
    public final static int RIGHT_INTAKE = 8;
    public final static int INTAKE_JAGUAR = 2;
    public final static int CATAPULT_LIMIT = 9;
    public final static int CATAPULT_LEFT = 5;
    public final static int CATAPULT_RIGHT = 4;
The print statement in teleopPeriodic() returns 0.0, and driveStick.getRawButton() at any button returns false.
Anyone got any ideas? I have no clue.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 12-05-2015, 18:41
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Joysticks not reading
are you trying to deloy your code with eclipse? That might not work at all, go back to netbeans
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-05-2015, 18:42
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
I'm sorry, I am in Netbeans, exactly as it was on kickoff day. If I upload the old robot project, the joysticks read properly.
After a quick check, the Joystick instance is non-null, it is being created, but it is only returning 0's.
I am using a red Afterglow Xbox 360 controller.
My FRC History:
Unread 12-05-2015, 19:04
Drive Coach
AKA: Antoine L.
Have you tried printing values in autonomous init? robot init? just to have a look if your code actually runs
Unread 12-05-2015, 19:05
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
robotInit() runs. I haven't tested autonomousInit(). It still works in old projects but won't work in this one.
My FRC History:
Unread 12-05-2015, 19:54
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As I recall, the axis numbers changed from 2014 to 2015. Oh well, joystick axis 4 appears to be the horizontal on the right joystick both years.
Is your controller perhaps mapping to a different number than control 1? Have you tried 0 or 2 as the argument to new Joystick() in robotInit? Actually, even easier as you seem to have the hardware, you could try plugging in "multiple different controllers" at the same time and see if any of them works.
Unread 12-05-2015, 20:17
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
I've already tried all of that, with gamepads, Xbox controllers, and actual joysticks. All of them had the same issue.
My FRC History:
Unread 12-05-2015, 20:29
Drive Coach
AKA: Antoine L.
also, the joystick mapping start at 0, so try changing your joystick port on your DS in the usb section
Unread 12-05-2015, 20:46
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Did you back-load (or do you still have) the 2014 driver station software installed on your classmate/laptop, or are you running 2015 driver station? I understand that there were significant protocol changes from 2014 to 2015.
Unread 12-05-2015, 20:53
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
I am running the 2015 DS with the option for 2014 DS and FMS mode selected.
My FRC History:
Unread 12-05-2015, 21:21
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
That doesn't seem to be what that mode is supposed to do.
From the wpilib screensteps documentation:
FMS Protocol - This controls which version of the DS to FMS communication protocol to use. This control is only needed when connecting to a 2014 FMS such as at a Week Zero event, where it should be set to '14. This control will reset to '15 (the setting required for 2015 Competition Events) each time the DS is started.
Unread 12-05-2015, 22:01
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Regardless, the joystick reads in our main program (although axis mapping is messed up), but not this one.
My FRC History:
Unread 13-05-2015, 04:38
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
By "our main program", do you mean the driver station? If so, then that's what Pault was saying would happen. It appears that the legacy mode is only for connections via the FMS, not direct connections. Here, it's not FMS that is the old version, but the robot computer. I believe that you will have to run the 2014 driver station or a work alike.
Unread 13-05-2015, 09:28
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
By main program I meant our main robot code from last year. The joystick returns values when the robot runs that program, but there is no difference (that I see) in how the joysticks are created and called in the new program, and it does not work.
My FRC History:
Unread 14-05-2015, 18:25
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Just an update, it WAS the joystick ports that were wrong. I created the Joystick object in port 1 and moved the controller to 0 instead of 1 on the DS and it worked. Thanks for the help guys!
My FRC History:
