Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
  #61   Spotlight this post!
Unread 12-05-2015, 19:52
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
FRC #0955 (CV Robotics)
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Re: pic: Small CIM in wheel swerve
Originally Posted by GeeTwo View Post
Does anyone have any insight on what 254 (or any other more "fluidly" driving team) uses to control their swerves or holonomic drives?
254 does not use holonomic drives. They do, however, scale inputs and use motion profiles to control their skid-steers.
2015 PNW District Champions (955, 1983, 2930)
Co-Creator of 955 OPR
  #62   Spotlight this post!
Unread 12-05-2015, 20:03
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I think that is because they don't need to.
Richard Wallace
since 2003
  #63   Spotlight this post!
Unread 12-05-2015, 20:13
Joining the 900 Meme Team
FRC #0079
254 doesn't swerve. But they DO use Cheezy Drive. It's designed to make driving in long sweeping arcs easier.
I know 16's controls encourage their drivers to drive in the long arcs you often see them do. I don't have nearly enough stick time with a bomb squad robot to explain it, hopefully I can get Jefferson to explain it a bit.
  #64   Spotlight this post!
Unread 12-05-2015, 20:34
AdamHeard's Avatar
Lead Mentor
I strongly suspect than many teams program both holonomic and redundant (e.g. swerve) drive controllers like tank, and if so, then of course they're driven that way. By "like tank", I mean that the primary drive is either two-tread style or arcade style, with options like strafing, translating in odd directions, translating odd directions while rotating, and rotating around a fixed point being either special cases or left for the driver to figure out.
When 3946 did mecanum (Aerial Assist, not our best tactical call), we had all of the translation in a single joystick, and rotation on the left and right "triggers" of the xBox controller. This did encourage a bit of combination maneuver - you could move towards the ball or goal while simultaneously rotating. Even I was able to do both at the same time within a couple of minutes when I did a demo at my office department's spring picnic. I'd personally like to have done a joystick with a long (+/- 60 to 90 degrees) proportional twist axis, but I wasn't mentoring programming that year, and I understand that we didn't have any joysticks up to the task, in any event.
Their swerve code is in the block below.
  #65   Spotlight this post!
Unread 12-05-2015, 22:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Gosh, that's the lightest-weight code I've ever seen.
  #66   Spotlight this post!
Unread 13-05-2015, 00:52
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Originally Posted by Andrew Schreiber View Post
30A breakers don't pop immediately. (http://www.snapaction.net/pdf/MX5%20Spec%20Sheet.pdf) So, a 30A breaker pulling 80A (which according to tests I've heard about is about the max you can get to a CIM given other loads on the system and the battery) will last 0.8 - 1.8 seconds. A 40A breaker will give you about twice that time. But that's assuming you're practically stalling the CIM. And it completely ignores the fact that, more than likely, the RoboRio will cut your motor power due to voltage drop.
Acceleration is also a function of code/driving/operator interface. All too often I see swerves driven like tanks. Go to point, pivot wheels, go sideways, pivot wheels again, go back to going forward. If you watch how teams who have mastered swerve (ok, I'm a 16 fan boy, I'll admit it) they tend to be much more fluid and rely less on raw power to accelerate from 0 in that direction. 254 does similar things when it comes to tank drives, it's why they seem to get away with gearing so much higher than other people.
Basically, while being able to pour more power for longer may seem like a good solution to the acceleration problem there's a fair bit more to it and utilizing it will mean your motors run cooler, your batteries last longer, and you can STILL out swerve most people.
That all being said, if I could easily find a 40A rated slip ring for comparable weight/cost of the 30A I'd choose it every time. But if I given the choice between a more complicated module (bevel), more complicated code (limit rotations), and limited continuous current (30A breaker) I'd choose limited current every time. But I'm a software engineer, I have a certain set of criteria I apply to decisions. Other folks with different backgrounds might make different decisions.
Yeah, I was looking at the breaker specs today and realized that for most scenarios the 30A will have nearly the same functionality as the 40A (as you said). That was the part of our power system that I wasn't sure about and I mentioned in my post. I definitely agree with you on the control code, that is incredibly important to any drivebase.
(2015-?): 973
(2012-2015): 955
