Go to Post Evolution is innovation. - Chris is me [more]
Unread 13-05-2015, 09:41
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
System temperature
Hi all
Just a general question
What are the usual temperatures for the control system to run at? I don't want to melt a brand new robots control system. Our new testbed robot will have one enclosed deck in it,that will be the control system deck. The second wil be exposed to the air, so no need for active coolant systems.
Do I even need active coolant? Fans are all we have, considering we will be mounting some form of compressor to the robot inside the control deck.
Unread 13-05-2015, 09:48
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Re: System temperature
In our experience, the compressor is going to be the main source of heat issues while testing. It's rare for a compressor to overheat over the course of a ~2 minute match, however when testing it can become a big issue if it starts melting things. Our team keeps lots of compressed air cans in stock because if you hold the canister upside down and spray the compressor it'll have an extreme cooling effect.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 13-05-2015, 10:05
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
If your "control system deck" is an enclosure that contains both the compressor and the roboRIO, you'll definitely want a fan to provide active cooling.
If I was building it, I'd have a small 40mm fan on the compressor heat sink, and a larger 80 or 120mm fan on the enclosure. Make sure your exit has the same area as the opening for the fan.
You can't go wrong by having some active cooling present.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 13-05-2015, 10:14
Generator of Entropy
FRC #2973 (The Mad Rockers)
The roborio spec says local ambient temperature limit is 40C (104F); that's pretty standard for electronics.
https://decibel.ni.com/content/servl...ifications.pdf
A small fan to provide some nominal air exchange should be fine. "Enclosed" can mean a lot of things, you'll want some vent holes for cross flow so that you're actually moving all the air with no dead spaces.
Unread 13-05-2015, 10:50
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Depends whether you overclock ir
Unread 13-05-2015, 11:43
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
The compressor can get VERY hot.
I would personally not mount the compressor inside an enclosure if at all possible.
I wouldn't have an issue with the rest of the electronics, but I would introduce a small cooling fan to circulate air inside, especially near the motor controllers.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 14-05-2015, 09:53
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
After some consideration we decided to go with 1 120 mm fan blowing back to front across the control board, and to mount the compressor externally. We also chose to utilize the talon Sr fan mounts ( yes those two screw holes are for mounting a fan, even though you shouldn't need one for the sr ) and mounted some small fans on those. The dam thing sounds like a jet engine taking off when it's on, but the amount of airflow is perfect. We also mounted a mesh grate over the 120 mm seeing as it's blowing from the outside in. Might get some debris flying out of the robot. Also mainly because i don't want to get my knuckles scraped off ( I hate those victor 888s for this specific reason )
The only question I have is what happens if we do overheat the compressor? This testbed tends to be on for long periods of time and in operation.
Unread 14-05-2015, 12:40
Knufire Knufire is offline
The tubing directly connected to the compressor output will eventually deform and pop out of the fitting. If you have the old Thomas compressor, it'd probably be a better fit for this as it's rated for a higher duty cycle.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-05-2015, 13:59
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
"Pop" isn't the right word, it's more like "bang". It sounded like a .22 going off when this happened during Ultimate Ascent practice.
Unread 14-05-2015, 14:08
evanperryg's Avatar
evanperryg evanperryg is offline
still doesn't like half champs
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Make sure your compressor is not enclosed. We tested the temperature of a compressor after 2 hours of drive practice (roughly 15-20% duty cycle), and the compressor had reached about 200 degrees. Motor controllers, depending on which type you use, can get pretty warm under heavy loads(i.e. drivetrain motors during defense). Otherwise, nothing else will get particularly warm, but always play it safe.
The compressor we did this test on, although it still works, is louder and does not fill the pneumatic system as quickly. Although it won't necessarily cause a catastrophic failure, it can cause permanent damage to the compressor.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 14-05-2015, 19:39
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
We've seen this happen on a few of the 90C's we have, if you smell burning it's probably a good idea to stop
(2015-?): 973
(2012-2015): 955
Unread 15-05-2015, 10:11
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
The robots are shooting at us! Gahh
Wonder how much noise a tank makes when it " spontaneously depressurizes"
Unread 15-05-2015, 10:13
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Our current robot has this same setup where the compressor is on the bottom level of the robot with lexan on top and bottom of the robot. The only difference is that this one has a fan blowing directly onto the compressor.
