Go to Post Losing is important. In some cases, more so than winning. - JackS [more]
Unread 13-05-2015, 12:59
Knufire Knufire is offline
Re: Modular Building Systems
You also might want to take a look at this webpage: http://www.vexrobotics.com/vexpro/ex...ides/?ref=tile
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 13-05-2015, 13:04
Aren_Hill's Avatar
Build Nifty Things
Originally Posted by GeeTwo View Post
Thanks, everyone, you've helped me convince the team to try this out. I'm trying to put together a budget and parts list for a versaframe build project, but I can't seem to find any documents that are complete enough to make a parts list, or even a complete tools list (e.g. hole saw size). Would someone please direct me to where I can find answers to the following (and follow-on) questions?
  • Are there any documents which show how the versaframe blocks come together?
  • It appears that you must drill large holes in the tubing for axles to pass through. How large they should be? Where they should be centered? What are the tolerances?
  • Are the clamping gearbox, clamping bearing and WCD bearings alternatives for or must they be used in conjunction with a face bearing mount? I can find pictures of the pieces either completely isolated or completely integrated, but nowhere in between.
  • How do the various gears, sprockets, and wheels say on the shafts - is it strictly shaft collar based, or do I need some more hardware?
Be sure to check out the drawings at the bottom of each project page, also the application and guides page has some instructions for some drivetrains to get a feel for the system.
-Aren
A guy who likes robots.
Unread 13-05-2015, 13:37
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This guide can answer a lot of your questions.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 14-05-2015, 07:18
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
.. Would someone please direct me to where I can find answers to the following (and follow-on) questions?
Originally Posted by Nyle View Post
For the clearance holes ..
The clamping gearbox and clamping bearing blocks do everything needed to hold the bearing, ..
Versablocks go on about the same as the plastic clamping bearing blocks, but ..
I don't have any experience with the WCP bearing blocks, ..
For holding everything on the shafts together all you need is collars..
Originally Posted by Mike Marandola View Post
Thanks all, these certainly cover all the ground I can think of. I thought I had been all over the Vex site, but completely missed the examples-guides portal page.
