Go to Post You know you're addicted to FIRST when to you: 4's company, 5's a crowd, and 6 is someone off-sides. - Tetraman [more]
Unread 13-05-2015, 14:34
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Best Sensor for Unlimited Rotation Swerve
Sidebar:
Before I get started, I initially titled this post "Best Sensor for Unicorn Swerve" because I THOUGHT that the term "Unicorn Swerve" was a reference to what I thought of as the "unicorn horn" i.e. shaft that drives the wheels (via a bevel gear), that is typically used on Unlimited Rotation Swerve Modules. But a little googling made me think that folks are using "unicorn swerve" to refer to 4 wheel swerve with 4 wheel independent steering (perhaps a reference to the rarity of such a beast when the term was coined?).
I like my interpretation better but since the purpose of language is communication, I suppose I had better defer to the views of others on this subject.
Preamble:
I know it will come as a shock to folks but I have fallen in love with Swerve all over again. I first used Swerve in 1998 (Ladder Logic) and I loved it then but after a number of years using it, I came to the conclusion that it was SUCH A RESOURCE HOG (no matter how you measured it: space, current, motors, weight, engineering effort, programming effort, karma,...), that I couldn't justify it any more. BUT... ...last year's experience using Wild Swerves from Team221.com together with the navX from Kauai Labs has me rethinking this. Our Coding Team really outdid themselves; Scorpion was one of the best behaved and easiest to drive robots I've been associated with. I am not sure I'm ever going back to non-swerve drives.
BUT... ...of course there are improvements. We want it to take up less space, weigh less, be more robust, use less power, easier to maintain, shoot freakin' lasers out its axles, ;-)
We've decided to look into using a swerve with a bevel gear drive system so that we can remote the drive motors (and perhaps add a shifter or multiple motors per wheel if the spirit moves us) and also because we think that in a game with Defense (a.k.a. the 2016 FRC game -- bet on it) we will certainly want to allow the steering axis to have unlimited rotation angle.
Which finally lets me get to my actual message.
In an unlimited rotation angle world, the natural thing to do is to put a quadrature encoder (like a US Robotics or a Grayhill or some such) in the swerve drive system somewhere and pretty much call it good.
But... ...I hate that idea. The main reason is that then you have to zero the count when the robot wakes up (or goes brain dead*). Yes, you can get around this with training and check lists and such but it is a long season, this decision is going to bite you in the tukhus before its over.
Here is what I would like.
  • Something that can deal with unlimited rotation (obviously)
  • Something that is 1:1 with the actual steering angle and does not require the controller to be zeroed (other than a constant programmed into the robot once and only changed if there is work on the robot -- if ever).
  • Something that has a resolution of under 1 degree -- preferably 1/10th a degree or better.
  • Something with as little noise as possible (To get reasonable responses, we use a lot of D Gain in our PID Loop. Noise is really tough for Deriviative Feedback loops to deal with.)
  • Something with at Digital Output if possible -- for two reasons. First, we had a heck of a time with noise on the 5V supply and on the GND from the RoboRIO, so it was hard to get a noise free signal out of a lot of our sensors (like pots for example). Second we ran out of analog inputs on the RoboRIO and had to add a coprocessor just to manage the extra analog signals. Not ideal. If we can put the steering position I2C or SPI, that may make our lives better -- though perhaps not because we are thinking of using the Talon SRX to do our PID loop, I don't think the Talon SRX likes getting its sensor input via anything other than Quadrature or Analog. So, I don't really know what I want in this department.
Anyway, I would like learn from folk with unlimited rotation swerve experience. What sensor scheme did you use and what are the pros (and cons) of those choices?
Do tell.
Dr. Joe J.
*don't get me started about FIRST's decision to allow the NI folks to allow the RoboRIO loose its mind at just under 7V -- this is something close to criminal. Really... this was a really dumb design direction given the customer base and the intended use of the RoboRIO.
Team #88, TJ2
Unread 13-05-2015, 14:49
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Best Sensor for Unlimited Rotation Swerve
I haven't built a swerve but your requirements for the sensor scream absolute rotary encoder to me. So for instance: <http://www.cui.com/catalog/components/encoders/absolute>
Buy at Digikey for $48.65 each
http://www.digikey.com/product-detai...050-ND/2278846
Edit: Also if the encoder is 1:1 with respect to rotation you could attach a standard rotary encoder and use the index to give you a home position. Turn each wheel left until you see the index then figure out that angle relative to forward for each wheel and reset the current angel of the wheel to that known value.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 13-05-2015, 14:51
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
On our swerve, we use absolute encoders. They use analog instead of digital output, though.
We've used them on our swerve for the past two years, and have been very reliable. They only require one offset constant, and then don't need to be calibrated again. Rotates infinitely and wraps around from 360-0.
I don't know what the model of the encoder is specifically, but maybe I can find that out.
Head Programmer / Driver
Unread 13-05-2015, 14:56
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
US Digital makes some analog absolute magnetic encoders that work great for unicorn drive (2783 used them for their implementation). Forgot the model though.
Unread 13-05-2015, 14:57
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm assuming this is the ma3?
R.C.
MadTown Robotics Team 1323
Unread 13-05-2015, 14:59
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
We've had good and bad experience with the AS5145B contact-less magnetic sensor (also available here) used as absolute encoders. They work well if you can guarantee the distance from the sensor to the shaft does not change, and you can embed the magnet to the end of the shaft.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-05-2015, 15:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You should certainly include Hall-effect rotary sensors in your investigation. They offer continuous rotation and do not drift, except at the mechanical end.
Unread 13-05-2015, 15:10
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Here is a link to the sensor that we have been using on our swerves. It meets all of you requests (and probably some you haven't encountered yet) except that it has an analog output, and you can get it for ~$10 if you shop around a little.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 13-05-2015, 15:14
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Have you interfaced these to the Talon SRX controllers at all?
Unread 13-05-2015, 15:18
Joining the 900 Meme Team
FRC #0079
Originally Posted by Joe Johnson View Post
Sidebar:
Preamble:
Do tell.
Dr. Joe J.
You could also use an indexing sensor such as a hall effect. The Encoder in WPILib supports indexing out of the box as does the Talon via CAN-Position Control.
My money is on the sensor Bryce listed because I'm cheap. And also lazy and don't like wiring extra sensors.
Unread 13-05-2015, 15:19
Paul Boehringer Paul Boehringer is offline
FRC #1218 (Vulcan Robotics)
Paul Boehringer will become famous soon enoughPaul Boehringer will become famous soon enough
We used indexed encoders this year. In my opinion an encoder such as the AM103 (made by cui) where the shaft goes through the encoder are much easier to deal with because you can mount them right to the gearbox plate. However each team has their own machining advantages and disadvantages.
Overall I would say its an extremely high priority to either use indexed encoders or continuous potentiometers on a swerve steering system. Though there are totally ways around it, I feel like doing it this way makes it much easier.
Unread 13-05-2015, 15:20
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
my team interfaced our swerve with the SRX, using these absolute encoders... http://www.andymark.com/product-p/am-2899.htm
works like a charm
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 13-05-2015, 15:24
zsnow's Avatar
zsnow zsnow is offline
Head of Satire
AKA: Zachary Snow
FRC #2122 (Team Tators)
zsnow has a spectacular aura aboutzsnow has a spectacular aura about
+1 On the magnetic absolute analog encoders from US Digital. We calibrate them and store an offset to zero, keeping it stateless.
Programming Lead: 2013-2015
Mechanical Dabbler: 2013, 2015
2015: IRI Semi Finalists 2338, 2122, 107, Tesla IDA, Utah Finalists 2122, 3230, 3405, EEA, WFFA, Arizona West Winners 2122, 3309, 5059, ICA
2014: Utah Winners 2122, 2996, 3191, ICA, Las Vegas Semi Finalists 2122, 399, 1572, ICA, CCC Winners 1678, 2122, 9073, ICA
2013: CalGames Winners 2122, 1678, 4171, Judges Award
2007-12: Lot's of wins and awards I wish I had been a part of
Unread 13-05-2015, 15:54
4-wheel independent-steering and independent-driven drivetrain, with unlimited steering rotation of the wheels and sensors, and no gaps in the sensor feedback
http://www.chiefdelphi.com/forums/sh...07&postcount=9
http://www.chiefdelphi.com/forums/sh...4&postcount=13
Unread 13-05-2015, 16:19
Knufire Knufire is offline
I have not used the US Digital MA3 in a swerve module, but I have used it in numerous other applications and it has always worked flawlessly.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
