Thread Tools |
Rating:
Display Modes |
Re: Brownout behavior - alternative design goals
The level is actually set by a hardware comparator. However it is likely that a work around could be implemented in the FPGA if needed.
Really? So the next question is who made the decision to put the PWM shutoff so high? With things we saw in 2013 and 2014, 7V is a number pretty easily hit by a 6 CIM drive, even if it is just for a few ms. Also why ever drop the 5v and 3.3v rails? It seems like disabling those causes more problems for teams, and troubleshooting sensor drops are harder then pwm drops.
Updated:
1. It will always be possible for the roboRIO to have less power than it needs to run, so load shedding features will continue to be useful for the great majority of teams. 2. Might be possible for the roboRIO to tolerate longer periods of low voltage. That said, robots operating for extended periods at 7 volts are visibly sick. 3. As FTAA, the only way I knew a robot was in brownout was to go stand behind the drivers and watch the display. We need to make brownout on the robot more visible, to avoid situations like the one Joe describes. Ideas: a. FMS field monitor should show "brownout count" statistic, separately showing stage 1 and 2 b. DS software should have a brownout indicator that stays lit if there's been a brownout c. DS stack light should change state for a second or so when there's a brownout 4. It's difficult to change the voltage of the stage 2 brownout, because it's a function of the power supply architecture. 5. It would be interesting to collect DS logs of machines in brownout, to see if at the point of outage the voltage has a steep slope. This would help assess the utility of changes to how stage 1/2 brownouts work. |
Later (alpha 2) when we decided that 5 V and 3.3 V supplies should not disable until black out, they were still down stream of the 6 V supply. At this point the hardware was already being manufactured and the power supply topology could not be changed with acceptable risk and schedule impact. Being down stream of the 6 V supply meant that the input they see goes away completely when the 6 V supply controller enters a fault state due to insufficient input voltage. This happens at about 6.25 V. This means that if the motor controllers respond (starting at 6.8 V) before the input drops to 6.25 V, the sensor supplies will not black out. |
They do not drop. Separate regulator. The internal pulls on all DIO / I2C / SPI lines are connected to the internal 3.3 V supply that is fed by the boost supply in roboRIO.
