Go to Post Support an awesome scholarship fund for deserving students by buying sweet CAH expansion packs? Heck yeah. - Cothron Theiss [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 14-05-2015, 18:52
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: pic: Manually machinable one-speed gearbox
Originally Posted by String View Post
A nicer way to do it might be to run 17t sprockets on the center wheel and 16t on the corners. You also get almost exactly an 1/8" drop then.
Would there be a problem if you ran the outer wheels slightly faster than the middle wheels?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 14-05-2015, 18:58
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
One solution, if a drop center is really desired, is to cut a pocket on the bottom of the center of the tube for the middle sprocket. IMHO, that's kind of defeating the point of chain in then.
Unread 14-05-2015, 19:00
String String is offline
String will become famous soon enoughString will become famous soon enough
The outer wheels would be shaved down to 3.75" diameter to ensure equal linear speeds on all wheels.
What 118 currently does as far as I know is use all 17t sprockets and use smaller diameter wheels on the corner, causing their larger diameter wheels to have greater linear speeds than the outer wheels. Jack's idea is a possibility to fix that problem without having to implement a drop center.
Unread 14-05-2015, 19:32
AdamHeard's Avatar
Lead Mentor
Is that a problem? Teams have been running uneven diameters for a long time.
Your wheels are slipping in one way or another in any motion other than going straight anyway.
The normal force is highest on the inner (larger diam) wheels as well.
Unread 14-05-2015, 19:39
Munchskull's Avatar
Team Role: CAD
So what you are saying is that some one could run sprockets with 16t-17t-16t all on the same wheel size?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 14-05-2015, 19:55
Jack S.'s Avatar
Jack S. Jack S. is offline
FRC #0624 (CRyptonite)
Jack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud of
I agree that it's not an issue. Game permitting I'd be surprised if we didn't run a setup very similar to 118's 2014 bot this upcoming season. The idea I presented would give an ideal set of linear speeds, but would likely lead to a few other issues down the line. For example, your center-to-center distances would no longer be nice easy numbers.
The width of the vexpro sprockets can easily be solved by shaving them down a little. Beware of the 16t sprockets, however, as we found that the chain would grind on the bearings, as Mason pointed out earlier.
All in all, 118 has it figured out. Their system is the easiest Texas Tube I've seen so far, no need to reinvent the wheel.
2013: 1539 Clover Robotics
2014-2016: 624 CRyptonite
Unread 14-05-2015, 20:29
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
To anyone who has run with "Texas Tube" in the past: How do you account for the stretching of the chain over the course of the season? There doesn't appear to be a lot of room for tensioners. Is this even a concern with the lengths of chain that are being used?
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 14-05-2015, 20:38
Jack S.'s Avatar
This season we built our system with no tensioners and never had to touch it. It ran very smoothly through three regionals and champs. I belive others have had similar success.
Unread 14-05-2015, 21:49
Alright, that's good to know! Now, since this is an awesome thread and I'm learning a lot from it, I'm going to ask another question.
Has anyone every thought about using timing belts instead of chain? Fitting it into a 2x1 box probably wouldn't be possible, but what about a 2x2 box. I'd imagine it would be even more of a "set it and forget it" scenario because a timing belt would be less likely to break than a chain.
Unread 14-05-2015, 21:55
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
That's a lot of weight you're gaining though (~2-4lbs depending on drivetrain), and you would have to settle for 1/8" wall probably. If teams say the chain doesn't break, then it doesn't break. That might be okay if you have the space and weight and mounting issues solved, because then you get a decent efficiency bonus.
Unread 14-05-2015, 22:21
Shray Mittal's Avatar
Shray Mittal Shray Mittal is offline
FRC #1477 (Texas Torque)
Shray Mittal is an unknown quantity at this point
This season, 1477 used a Texas Tube style chassis. On a 4WD with all omni wheels, we used VexPro 16t #25 sprockets. We had tensioners on both our practice bot and our competition bot, and never used them on either robot. We had no issues with the 16t sprockets, and our chain runs were more than 200 links long. Game permitting, we will likely be running a Texas Tube style drive chassis again. Our experience with #25 chain in 2x1 tube has been outstanding thus far.
This is something I've been thinking about a lot lately. If using 1/16th wall 2x1 tube, it is theoretically possible to run 24t pulleys and 9mm belts from VexPro inside the 2x1. This could result in an extremely lightweight and efficient drive, at the cost of some structural integrity in the drive chassis. In my experience, #25 chain is less likely to break than 9mm timing belts, but is heavier and less efficient, assuming both the belt/pulley and chain/sprocket are assembled correctly.
http://www.chiefdelphi.com/forums/sh...ad.php?t=94701
Here is a picture of 2791 running timing belts inside tube extrusion.
Unread 14-05-2015, 23:10
Knufire Knufire is offline
2791 has continued iterating on their belt-in-tube drive since then. Chris Picone would be the guy to talk to about that.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-05-2015, 23:18
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
192 has also used belt in tube for the past three years. 15mm wide GT2 in 2x2 .125 wall. With our set up and access points it's incredibly fast to assemble and tear down even though you'll never need to.
It is possible to run 15mm wide belts in 2x1.5 but you'd have to bore out the pulleys around the bearings or move the bearings out. I wouldn't recommend 9mm belt in the DT unless you had a proper tensioning system like 971 and even then they have had issues breaking belts.
Unread 15-05-2015, 00:46
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
How are your access points for belt in tube set up? How is it assembled?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 15-05-2015, 00:55
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Been running belt in a tube structure formed from sheet metal for the past three years with no issues. The sheet metal works great because we can start with a readily available belt/sprocket combo and size the tube accordingly, rather than the other way around. Access is achieved by opening up the entire side of the tube, which makes installation a lot easier than the through-the-end approach or small access pockets required by extrusion.
It is a fair bit larger than the texas tube approach, due to the increased sprocket diameter/width, and the need to add additional clearance for the rivets which hold the tube together, but it works well with our resources, and we like the insurance it provides.
