Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 15-05-2015, 16:44
MultipleMono's Avatar
MultipleMono MultipleMono is offline
Programmer & IT Guy
FRC #3128 (Aluminum Narwhals)
MultipleMono is an unknown quantity at this point
Re: New tool for C++ Programming for old cRIOs
Oddly enough, this plugin worked fine for me without the FRC C++ plugin installed. I do have the Java one though.
I had a different problem, though. At first, I had issues with make, but I set it to use the internal builder by default, and it worked fine.
Moreover, the commands that it tried to run as a post-build step (the ones that make, build, and link the constructors and destructors file) failed on the first step. It seems like eclipse was not honoring the pipe characters. I suspect that there may have been an issue with me having Git's included posix tools in my path, but thought that I tried removing them and it still failed. Then, I noticed that Eclipse seemed to be putting backslashes in front of every double quote.
So, I tried executing the commands one-by-one in cmd, removing the backslashes, and they worked fine. I then moved them into a batch file, and they kept working fine. I then set it so that eclipse executed the batch file as a post-build step.
The batch file is here.
Did anyone else have this problem?
