Go to Post Age should not be a speed bump to creativity. - Greg Needel [more]
Unread 16-05-2015, 01:20
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: pic: Offseason Gearbox
Originally Posted by asid61 View Post
I noticed on the plates your radii are pretty variable, with a 0.04 radius in one of the plates. Depending on the machine, this could make it take considerably longer to machine than using a single larger radius throughout, as a larger endmill can take off more material in general in a certain amount of time.
I think your being a little picky. CAM software will try to cut the tightest radius it can with tool specified. You should be able to cut 90% of the lightening holes with a .25 end-mill and then finish things up with a 1/8 end-mill. All in all it should take 8-15 minutes a plate with decent end-mills.
2016: FRC 865 Mentor
