Re: pic: Offseason Gearbox
I dislike using anything less than 1/4" diameter in 1/4" plate. with 1/4" cutter diameter you can go full depth (with a reasonably rigid machine and good chip evacuation). 3/16" and smaller won't allow you to do that. |
Is the bering on the output shaft pushed out some?
Yeah the flange is actually on the inside of the tubing and that gap is for the thickness of the tubing.
How will you get it into the tubing?
And once you do how will you get it to stay in the wall of the tubing?
One of the things I was playing around with in this design was running the timing belts through the tubing of the drive base. I have an access hole for putting the belts through that can easily fit the bearing. The entire shaft would be held together with snap rings. The grooves for those snap rings are on either end of the output shaft. |
#7
I have a Vex 18T pulley for 5mm HTD timing belts. The pulley thickness is for a 15mm belt.
#9
I would recommend at least 24t or larger if your using HTD.
#10
When doing a gearbox in the back like this rather than the middle, keep in mind that belt connecting the back wheel to the middle wheel will always see the full load of the drive base. So it's extra important to use a properly sized pulley. |
#11
Am I correct in assuming that you need a larger pulley to keep the belt from slipping off of the pulley?
The more I hear about this I am starting to lean towards chain drive to run through the tubes. My only draw back is keeping the chain tensioned. What would be the best way to keep the chain tight while it is in the tube? |
#12
If you have the proper center-to-center distance on the chain, it should stay tensioned. 5188 did the calculated center-to-center + 0.018" this past year, and the chain stayed perfectly tensioned all season. This was based on Paul Copioli's recommendation and further coborrated by the testing done in this thread. However, with the chain in tube, remember that a tigher chain is more difficult to install, and there isn't anywhere for the chain to go, so the added distance may not be necessary. |
#14
That said, you never have to tension a properly dead spaced belt in tube drive. It has its pluses. It's just not Quote:
For a very extreme example, our chain elevator this year had a nice 13 foot long loop that was dead spaced, and it stretched noticeably over the course of a few hours of low to no load testing. It is a function of sprocket diameter, chain length, and several other factors. At the size of sprockets used in west coast drives, it's a factor. The other important caveat here is that your chain and sprocket should be constrained by the tube itself for this to work (very close to inner walls of tubing). One of the reasons chain in tube seems to work so well is that there is nowhere for the chain to go when it does stretch, preventing the jumping problems found with looser chains. |
#15
