| I'm over the moon for you. |
| Thread Tools |
Rating:
Display Modes |
#16
Re: "standard error" of OPR values
Kind of reminds me of a joke I heard this past weekend that was accidentally butchered:
A physicist, engineer and a statistician are out hunting. Suddenly, a deer appears 50 yards away. The physicist does some basic ballistic calculations, assuming a vacuum, lifts his rifle to a specific angle, and shoots. The bullet lands 5 yards short. The engineer adds a fudge factor for air resistance, lifts his rifle slightly higher, and shoots. The bullet lands 5 yards long. The statistician yells "We got him!" ************************************************** ******** A really interesting read into "what is important" from stats in basketball: http://www.nytimes.com/2009/02/15/ma...ewanted=1&_r=0 +/- system is probably the most similar "stat" to OPR utilized in basketball. It is figured a different way, but is a good way of estimating impact from a player vs. just using points/rebounds and.... The article does a really good job of doing some comparison to a metric like that to more typical event driven stats to actual impactful details of a particularly difficult to scout player. I really enjoy the line where it discusses trying to find undervalued mid pack players. Often with scouting, this is exactly what you too are trying to do. Rank the #16-#24 team at an event as accurately as possible in order to help foster your alliances best chance at advancing. If you enjoy this topic, enjoy the article, and have not read Moneyball, it is well worth the read. I enjoyed the movie, but the book is so much better about the details. |
#17
There's an equivalent economists' joke in which trying to feed a group on a desert island ends with "assume a can opener!" ************************************************** ******** Quote:
In baseball, this use of statistics is called "sabremetrics." Bill James is the originator of this method. Last edited by Citrus Dad : 13-05-2015 at 18:41. Reason: added about sabremetrics |
#18
Getting back to the original question: Quote:
So for those of you who answered "yes": Pick an authoritative (within the field of statistics) definition for standard error, and compute that "standard error" for each Team's OPR for the attached example. Last edited by Ether : 15-05-2015 at 19:16. |
#19
... and for those of you who think the answer is "no", explain why none of the well-defined "standard errors" (within the field of statistics) can be meaningfully applied to the example data (provided in the linked post) in a statistically valid way.
#20
Here's a poor-man's approach to approximating the error of the OPR value calculation (as opposed to the prediction error aka regression error):
1. Collect all of a team's match results. 2. Compute the normal OPR. 3. Then, re-compute the OPR but excluding the result from the first match. 4. Repeat this process by removing the results from only the 2nd match, then only the 3rd, etc. This will give you a set of OPR values computed by excluding a single match. So for example, if a team played 6 matches, there would be the original OPR plus 6 additional "OPR-" values. 5. Compute the standard deviation of the set of OPR- values. This should give you some idea of how much variability a particular match contributes to the team's OPR. Note that this will even vary team-by-team. Thoughts? Last edited by wgardner : 16-05-2015 at 14:14. |
#21
The question is this thread is how (or if) a standard, textbook, widely-used, statistically valid "standard error" (as mention by Citrus Dad and quoted in the original post in this thread) can be computed for OPR from official FRC qual match results data unsupplemented by manual scouting data or any other data. |
#22
Team Original OPR Mean OPR Standard Deviation StdDev / Mean 1023 119.9222385 120.0083320153 11.227427964 0.0935554038 234 73.13049299 72.801129356 8.9138064084 0.1224404963 135 71.73803792 72.0499437529 7.953512079 0.1103888728 1310 68.29454232 69.3467152712 14.1978070751 0.2047365476 1538 66.51660956 65.739882921 10.0642899215 0.1530926049 1640 63.89355804 63.1124212044 12.5486944006 0.1988308191 4213 59.83218159 60.3799737845 9.7581954471 0.1616131117 2383 59.3454496 58.4390556944 8.8170835924 0.1508765583 5687 58.89565276 58.0801454327 8.5447703278 0.1471203328 2338 57.52050487 57.8998084926 9.9345796042 0.1715822533 68 57.31570571 57.5000280561 7.3734953486 0.1282346391 2342 56.91016998 57.2987212179 6.6038945531 0.115253786 2974 55.52108592 57.1342122847 8.3752237419 0.1465885921 857 56.58983207 56.5258351411 7.2736015551 0.1286774718 2619 55.87939909 55.7690519681 8.4202867997 0.150984937 314 54.93283739 54.2189755764 9.2781646413 0.1711239385 4201 54.36868175 53.4393101098 10.5474638148 0.1973727541 2907 52.20131966 52.8528874425 7.542822466 0.1427135362 360 50.27624758 50.4115562132 7.0992892482 0.1408266235 5403 50.29915841 50.3683881678 6.7117433122 0.133253089 201 45.9115291 44.7743914139 8.4846178186 0.189497111 2013 44.91032156 44.6243506137 6.8765159824 0.1540978387 3602 44.27190346 44.0845482182 9.1690079569 0.2079868872 207 43.76003325 43.534273676 9.6975195297 0.2227559739 1785 42.88695283 43.4312399486 8.2699452851 0.1904146714 1714 43.01192386 42.548981107 10.4744349747 0.2461735793 2848 42.09926229 42.3315382699 5.5963086425 0.1322018729 5571 41.52437471 41.7434170692 9.1647109829 0.2195486528 3322 41.46602143 41.5494849767 7.1743838875 0.1726708259 4334 40.44991373 41.05033774 8.7102627815 0.2121849237 5162 40.45440709 40.9929568271 8.2624477928 0.2015577414 5048 39.89000748 40.3308767357 11.0199899828 0.2732395344 2363 39.94545778 40.1152579819 6.6177263936 0.1649678134 280 39.5619946 39.5341268065 7.3717432763 0.1864653117 4207 38.2684727 39.4991498122 6.9528849981 0.1760261938 5505 39.67352888 38.9668291926 11.3348728596 0.2908851732 217 36.77649547 37.4492632177 6.4891284445 0.1732778668 836 36.43648963 37.0437210956 12.1307341233 0.3274707228 503 36.81699351 36.7802949819 7.9491833149 0.2161261436 1322 36.38199798 36.7254993257 8.5268395114 0.2321776332 4451 35.19372256 35.3483644749 9.807710599 0.2774586815 623 34.52165055 35.1189107974 7.930898959 0.2258298671 1648 35.50610406 35.0638323174 10.815198205 0.3084431304 51 34.66010328 34.6703806244 5.4485310273 0.157152328 122 34.32806143 33.5962803896 7.5092149942 0.223513285 115 31.91437124 31.3399395607 8.4108320311 0.2683742263 5212 30.01729221 30.4525516362 8.9862156315 0.2950890861 1701 29.87650404 30.3212455768 6.3833025833 0.2105224394 3357 29.17742219 29.6022237315 6.381280757 0.2155676146 1572 29.88934385 29.5148636895 7.882621955 0.2670729582 3996 29.80296599 29.071104692 12.1221539603 0.4169829144 2655 26.12997208 26.8414199039 8.2799141902 0.3084752677 3278 27.75400612 26.676383757 8.7090459236 0.3264702593 2605 26.77170149 26.4416718205 7.2093344642 0.2726504781 2914 25.16358084 25.6405460981 8.2266061339 0.3208436397 5536 25.12712518 25.537683706 8.9692243899 0.3512152666 108 25.12900331 24.9994393089 8.1059495087 0.3242452524 4977 23.84091367 24.1678220977 8.8309117942 0.3653995697 931 20.64386303 20.6395850124 9.7862519781 0.4741496485 3284 20.6263851 20.3004828941 7.7358872421 0.3810691244 5667 20.24853487 20.2012572648 10.5728126478 0.5233739915 188 19.63432177 19.5009951172 8.527091207 0.4372644142 5692 17.52522898 16.9741593261 9.9533189003 0.5863806689 1700 15.35451961 15.0093164719 7.5208523959 0.5010789405 4010 12.26210563 13.9952121466 9.8487154699 0.7037203414 1706 12.6972477 11.7147928015 6.1811481569 0.5276361487 3103 12.14379904 11.6822069225 8.4008681879 0.7191165371 378 11.36567533 11.6581748916 8.2483175766 0.7075136248 3238 8.946537399 9.2298154231 9.6683698675 1.0475149745 5581 9.500192257 8.7380812257 8.2123397521 0.9398333044 5464 4.214298451 5.4505495437 7.2289498778 1.326279088 41 5.007828439 4.3002816244 9.0353666405 2.1011104457 2220 4.381189923 4.2360658386 6.880055327 1.6241615662 4364 4.923793169 3.504087428 8.6917749423 2.4804674886 1089 1.005273551 0.9765385053 6.9399339807 7.1066670109 691 -1.731531162 -1.2995295456 11.9708242834 9.2116599609 In terms of whether this is a valid way of looking at it, I'm not sure--the results seem to have some meaning, but I'm not sure how much of it is just that only looking at 200 scores is even worse than just 254, or if there is something more meaningful going on. *Using python's random.sample() function. This means that I did nothing to prevent duplicate runs (which are extremely unlikely; 254 choose 200 is ~7.2 * 10^55) and nothing to ensure that a team didn't "play" <3 times in the selection of 200 scores. |
#23
The method I propose above gives a standard deviation measure on how much a single match changes a team's OPR. I would think this is something like what you want. If not, can you define what you're looking for more precisely? Also, rather than taking 200 of 254 matches and looking at the standard deviation of all OPRs, I suggest just removing a single match (e.g., compute OPR based on 253 of the 254 matches) and looking at how that removal affects only the OPRs of the teams involved in the removed match. So if you had 254 matches in a tournament, you'd compute 254 different sets of OPRs (1 for each possible match removal) and then look at the variability of the OPRs only for the teams involved in each specific removed match. This only uses the actual qualification match results, no scouting or other data as you want. |
#24
And just to make sure I'm being clear (because I fear that I may not be):
Let's say that team 1234 played in a tournament and was involved in matches 5, 16, 28, 39, 51, and 70. You compute team 1234's OPR using all matches except match 5. Say it's 55. Then you compute team 1234's OPR using all matches except match 16. Say it's 60. Keep repeating this, removing each of that team's matches, which will give you 6 different OPR numbers. Let's say that they're 55, 60, 50, 44, 61, and 53. Then you can compute the standard deviation of those 6 numbers to give you a confidence on what team 1234's OPR is. Of course, you can do this for every team in the tournament and get team-specific OPR standard deviations and an overall tournament OPR standard deviation. Team 1234 may have a large standard deviation (because maybe 1/3 of the time they always knock over a stack in the last second) while team 5678 may have a small standard deviation (because they always contribute the exactly same point value to their alliance's final score). And hopefully the standard deviations will be lower in tournaments with more matches per team because you have more data points to average. |
#25
I am not defining "standard error".
I am asking you (or anyone who cares to weigh in) to pick a definition from an authoritative source and use that definition to compute said standard errors of the OPRs (or state why not): Quote:
Citrus Dad asked why no-one ever reports "the" standard error for the OPRs. "Standard Error" is a concept within the field of statistics. There are several well-defined meanings depending on the context. So what am trying to do is this: have a discussion about what "the" standard error might mean in the context of OPR. |
#27
@ Citrus Dad: If you are reading this thread, would you please weigh in here and reveal what you mean by "the standard errors" of the OPRs, and how you would compute them, using only the data in the example I posted? Also, what assumptions do you have to make about the data and the model in order for the computed standard errors to be statistically valid/relevant/meaningful, and what is the statistical meaning of those computed errors? Last edited by Ether : 16-05-2015 at 23:11. |
#29
OPR should then yield an estimate of the mean of this distribution. An estimate of the standard deviation can be obtained, as mentioned, by taking the RMS of the residuals. To approximate the standard deviation of the mean (which is what is usually meant by "standard error" of these sorts of measurements), one would then divide this by sqrt(n) (for those interested in a proof of this, simply consider the fact that when summing random variables, variances add), where n is the number of matches used in the team's OPR calculation. This, of course, fails if the assumptions we made at the outset aren't good (e.g. OPR is not a good model of team performance). Moreover, even if the assumptions hold, if the distribution of the random variable describing a team's performance in a given match is sufficiently wonky that the distribution of the mean is not particularly Gaussian then one is fairly limited in the conclusions they can draw from the standard deviation, anyway. Last edited by Oblarg : 17-05-2015 at 03:30. |
#30
What you say holds if one is taking a number of independent, noisy measurements of a value and computing the mean of the measurements as the estimate of the underlying value. So that would work if OPR was computed by simply averaging the match scores for a team (and dividing by 3 to accommodate for 1/3 of the match score being due to each team's contribution). But that's not the way OPR is computed at all. It's computed using linear regressions and all of the OPRs for all of the teams are computed simultaneously in one big matrix operation. For example, it isn't clear to me what n should be. You say "n is the number of matches used in the team's OPR calculation." But all OPRs are computed at the same time using all of the available match data. Does n count matches that a team didn't play in, but that are still used in the computation? Is n the number of matches a team has played? Or the total matches? OPR can be computed based on whatever matches have already occurred at any time. So if some teams have played 4 matches and some have played 5, it would seem like the OPRs for the teams that have played fewer matches should have more uncertainty than the OPRs for the teams that have played more. And the fact that the computation is all intertwined and that the OPRs for different teams are not independent (e.g., if one alliance has a huge score in one match, that affects 3 OPRs directly and the rest of them indirectly through the computation) seems to make the standard assumptions and arguments suspect. Thoughts? Last edited by wgardner : 17-05-2015 at 07:20. |
