Re: pic: Short coaxial swerve module
I won't dispute worm gears high reductions but i wouldn't describe them as relatively efficient. The highest efficiently you'll get is 86% with a four lead worm. At best this would be replacing the two stages before the co-axial, a miter stage and a timing belts stage, each around 95% or higher. I too am unsure of the benefits of a horizontal cim for a coaxial swerve but I don't think a worm gear would be beneficial on the Cim motor. However, using a worm gear for the steering motor is a different issue and has more merits in my opinion.
Amazing as usual.
Thank you for sharing this on CD.That weight is interestingly low. What is the thickness of the top plate? ARe you still using 1/4" diameter balls for the 16-style bearing? EDIT: And which miter gears are those? They don't look like Vex ones. |
The weight is a little lower than I expected as well, considering the added complexity. I attribute the lower weight to the caster portion being smaller. It now fits into a 72 tooth 20 dp gear from VEX instead of an 84 tooth. The top plate is 0.25'' thick so that the plate that the CIM mounts to can be attached to the side of it with 6 32 bolts. Yes, the steering gear and the bottom gearbox plate have grooves milled in them for 0.25" delrin balls. The first set of miter gears are 1 module, 20 tooth because they have 8mm bore, and they're a little smaller. The later ones, in the caster, are 20 tooth 20 dp, because my team has had success with them in the past. They are both made of steel, and from SDP-SI. |
