Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 18-05-2015, 19:40
Insanity000 Insanity000 is offline
Rookie Year: 2015
Insanity000 will become famous soon enoughInsanity000 will become famous soon enough
Re: IRI Application List
Originally Posted by Travis Hoffman View Post
I'm not quite understanding your request.
If you scroll to the leftmost column on the first page, you can use that to provide relative ranks of the applicants after you conduct whatever sorting you choose. Just perform your sort and then fill down in the first column 1 through 106.
I see now, you are able to sort by each column from lowest to highest and vice versa. Thanks!
  #77   Spotlight this post!
Unread 18-05-2015, 19:42
O-H
FRC #0048 (Delphi E.L.I.T.E.)
If you want to do a multi-criteria sort, right click anywhere in the data table, select "Sort" and then "Custom Sort...".
Also, if you click the + signs next to the state and province locations in the pivot table on the right, that location will expand to show which teams from that location applied.
  #78   Spotlight this post!
Unread 18-05-2015, 21:22
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
This is the download from the website and should have all applications submitted.
It has been checked against the emails / PMs received from teams as well.
FINAL APPLICATION LIST
1 1
2 11
3 16
4 20
5 27
6 33
7 48
8 51
9 67
10 68
11 74
12 107
13 111
14 118
15 125
16 135
17 148
18 179
19 193
20 195
21 217
22 225
23 226
24 233
25 234
26 245
27 316
28 330
29 340
30 359
31 379
32 384
33 456
34 461
35 469
36 503
37 548
38 573
39 624
40 744
41 829
42 865
43 868
44 1023
45 1024
46 1058
47 1086
48 1114
49 1126
50 1218
51 1310
52 1325
53 1511
54 1619
55 1625
56 1640
57 1657
58 1675
59 1711
60 1720
61 1730
62 1741
63 1756
64 1806
65 1817
66 1902
67 1923
68 1987
69 2039
70 2056
71 2122
72 2175
73 2194
74 2337
75 2338
76 2468
77 2502
78 2512
79 2587
80 2590
81 2614
82 2826
83 2852
84 2867
85 2877
86 3015
87 3098
88 3130
89 3641
90 3824
91 3928
92 4039
93 4096
94 4143
95 4265
96 4272
97 4499
98 4587
99 4655
100 4678
101 4967
102 5012
103 5030
104 5188
105 5254
106 5413
107 5484
108 5576
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
  #79   Spotlight this post!
Unread 18-05-2015, 21:42
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Originally Posted by MMmmDUDE View Post
And 2175!
Now you can add 3130 too
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #80   Spotlight this post!
Unread 18-05-2015, 21:47
O-H
FINAL RELEASE based on the final 108-team applicant list. I deleted my prior post with the spreadsheet based on the partial applicant list.
For fun, I put together an Excel spreadsheet to summarize some stats for the 108 applicants.
My data source was Ed Law's final post-championship Excel release, which can be found here.
Please note that Einstein results are not factored into this spreadsheet.
Playoff Points are assigned per event based on the "30 for winner, 20 for finalist, 10 for semifinalist" method used by districts.
There is no weighting given to regionals vs. districts vs. district championships vs. divisions (good luck with that), nor is there any consideration for whether playoff points were earned as an alliance captain, 1st pick, or 2nd pick. If you want to play around with those things, more power to ya.
You can sort the information however you like, but instead of defaulting the list to boring old OPR, I did a multi-criteria sort based on the following sort order:
  • Average Playoff Points Per Event (largest to smallest)
  • Average Event Seed (smallest to largest)
  • OPR Rank (smallest to largest)
Finally, here's the breakdown of applicants by location:
File Type: xlsx 2015 IRI Applicant Information for Distribution.xlsx (2.97 MB, 296 views)
  #81   Spotlight this post!
Unread 18-05-2015, 22:34
MMmmDUDE MMmmDUDE is offline
FRC #2512
MMmmDUDE is an unknown quantity at this point
YES, 3130 has a great team and robot. It has been great competing with them at Northern Lights and winning the Minnesota state championship with them. Go 3130!
  #82   Spotlight this post!
Unread 18-05-2015, 22:38
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Thanks for taking the time to put this together Travis!
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
  #83   Spotlight this post!
Unread 18-05-2015, 23:08
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
I hope all 4 MN teams that applied get(2175, 2502, 2512, 3130) in. If they do MN will be well represented at IRI this year
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
  #84   Spotlight this post!
Unread 19-05-2015, 15:10
O-H
A minor omission - my original spreadsheet is missing the number of events attended for 2 teams (5484 and 5576). Fixed the error and posted below.
File Type: xlsx 2015 IRI Applicant Information for Distribution v2.xlsx (2.97 MB, 132 views)
  #85   Spotlight this post!
Unread 21-05-2015, 16:20
JOClarke's Avatar
JOClarke JOClarke is offline
AKA: Chainsaw
FRC #0384 (Sparky)
JOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to all
I know that the IRI committee will send teams an email invitation to the event, but does anybody have a date of when this will happen.
Never stop thinking! It all begins with a spark! Growing up in a FIRST World!
  #86   Spotlight this post!
Unread 21-05-2015, 16:24
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
The website said the 22nd which is tomorrow.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #87   Spotlight this post!
Unread 21-05-2015, 16:33
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I hate that Hawaii to IRI flights are in the 1300-1500 range! Every year it gets higher and higher.
Good and bad if we make the cut.
  #88   Spotlight this post!
Unread 21-05-2015, 21:38
O-H
Could you link to where you saw that date listed?
  #89   Spotlight this post!
Unread 21-05-2015, 21:43
KosmicKhaos's Avatar
KosmicKhaos KosmicKhaos is offline
Calm Cool Collected
AKA: Andrew Thompson
FRC #1126 (SparX)
Rookie Year: 2015
KosmicKhaos has a spectacular aura aboutKosmicKhaos has a spectacular aura about
I believe it has been removed now but it was originally under the 2015 IRI Application tab while applications were still open. During the period when they were open it listed some other dates such as when the applications open, when they close, etc. He is correct though, the website, when it had the dates up, said on or close to May 22.
  #90   Spotlight this post!
Unread 21-05-2015, 21:55
O-H
OK. I'd bet the over on that date. Never an easy decision.
