Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Unread 19-05-2015, 11:30
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Construction with gussets and bolts
Originally Posted by Joseph Smith View Post
I've been investigating some new design and construction methods that my team hasn't explored in the past, and I really want to try assembling the frame and important structures with machined gussets and bolts. I have a few questions for teams who have used this construction method. In this scenario, I'd be using two gussets, top and bottom, to create a 90 degree joint between two lengths of rectangular aluminum tubing, all 1/8" wall thickness.
1. Is it better to put a long bolt all the way through and use a nut on the other side, or to tap the gusset and tubing and use shorter bolts?
2. If a bolt all the way through is used, are large washers needed to spread the load to prevent the tube from being crushed?
3. If the parts are tapped and a short bolt is used, would it be preferable to tap both the gusset and the tubing or to drill clearance on the gusset and only tap the tubing?
4. Is locktite a necessity with the tapping method?
5. What has been your overall experience with this method of construction? Pros/Cons?
Thanks!
Are you set on using bolts? The VersaFrame line has been designed to use rivets and many teams have been very successful with it so far.
