Go to Post You miss 100% of the shots you don't take. - AdamHeard [more]
Unread 19-05-2015, 15:09
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
pic: Team 3940 CyberTooth 2015 Drivetrain
Unread 19-05-2015, 15:11
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: Team 3940 CyberTooth 2015 Drivetrain
How are the gears kept on the bearings?
We use a very similar style of geardrive but we put bearings on the axles of the idler gears and use a hex shaft with snap ring groves to hold the gears in place.
Unread 19-05-2015, 15:12
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
The visual properties on the CIMs aren't the same. Try again.
On a more serious note, beautiful machine this year that gear drive is slick!
Unread 19-05-2015, 15:43
Commander Canada
The bore in all of the gears is sized for a tight press-fit. It worked great for us.
Thanks! We're a little obsessive about overall machine aesthetic and team imagery.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Last edited by Nick Lawrence : 19-05-2015 at 15:44. Reason: English is hard sometimes.
Unread 19-05-2015, 16:03
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
What was the reasoning behind the gear drive over something easier to implement? It's really cool looking, but was there a reason regarding function that you went this way?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 19-05-2015, 16:35
Commander Canada
Our original chassis requirements included a few distinct constraints:
- We wanted the chassis to have a 28" x 32" footprint in 'long' orientation
- We wanted the front of the chassis to have an opening large enough for both totes and recycling containers.
- We wanted to have a reliable H drive
- We wanted to use the new AndyMark DuraOmni Wheel
- We wanted to have a raised center wheel to cross the scoring platforms.
- We did not want to spend a lot of time assembling/disassembling the robot for Transportation Configuration requirements.
Furthermore, we did not want to pursue serpentine chain or belt options as we were far less experienced with these ideas as a team, and we were concerned about the reliability of these methods. Gears ended up allowing us to make the drive modules much narrower, allowing for this opening in the front of the chassis to be large enough for our initial constraints. We also really loved how a drivetrain like this is virtually maintenance free with periodic lubrication.
-Nick
Unread 20-05-2015, 08:52
roboryan roboryan is offline
FRC #0930 (B.E.A.R.s)
roboryan is just really niceroboryan is just really niceroboryan is just really niceroboryan is just really nice
Looks awesome! Being my team is trying to focus on aesthetic and got our first ever custom sheetmetal chassis this year. I was wondering what thickness of sheetmetal are you guys using? We went with 1/8" but we think it might be alittle thick for our purposes but we aren't quite sure.
Unread 20-05-2015, 09:50
Commander Canada
Thanks! This chassis uses 1/8" 5052 AL. With a rigid one-piece bumper frame like Team 33, you can get away with a lot thinner. 1/8 does give you plenty of piece of mind when using AL sheet, as long as it is is adequately lightened.
-Nick
Unread 20-05-2015, 10:16
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Nice. How do you keep the center "H" drive from lifting the robot?
Unread 20-05-2015, 11:40
Commander Canada
The strafe module assembly doesn't produce enough torque to lift the robot when run with MiniCIMs. Two CIMs got pretty close to lifting the chassis, but even then it wasn't a problem.
- Nick
Unread 22-05-2015, 19:43
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Does the center HiGrip wheel cause scrubbing when translating left or right?
Unread 22-05-2015, 20:20
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Originally Posted by Nick Lawrence View Post
-snip-
-snip-
My interpretation is that the center HiGrip wheel only contacts the scoring platform, never the carpet.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
